Tires and offset
Old Feb 28, 2006 | 09:22 PM
jimmers's Avatar
jimmers
Default Tires and offset
Im going to buy new tires and rims for my 90. I want to put 315's on the rear but am worried about 2 things. Im told that a rim with a 50mm offset will fit totally in the wheel well with nothing sticking out past the fender. Im also told that they will not rub against the inner wheel well with normal ride height. Is this true? I want to be sure of this because I have pretty strict laws where I live about things like that.
Old Feb 28, 2006 | 09:39 PM
qws's Avatar
qws
I have the 315's on my 84 and they don't rub at all. The only problem I have is that the passenger side tire does stick out about 1.5 inches from the fender where the drivers side tire does sit flush. As of yet there has been no explanation of why this is. On others cars it doesn't but mine does. And we have been through everything, one of lifes mystery's
Old Feb 28, 2006 | 09:40 PM
MYCoupe's Avatar
MYCoupe
The rim part is true, but the tires will stick out 1/4-1/2" past the wheel well. Do a search and you'll probably be able to find some pics. If the laws are that strict in Canada, then you might have to add a set of the GS flares.
To Tires and offset
