Security Light
Old Mar 4, 2006 | 04:05 PM
Demonic85's Avatar
Demonic85
Default Security Light
I have a new electrical problem now. I replaced the headlight actuator relay. I disconnected the negative terminal on the battery before doing so. After hooking the battery back up, the Security light on the dash starts flashing and making noise at ALL times unless I start the car up. It does it when all the doors are closed and the key is in the ignition. Only goes away if I disconnect the battery, take out the fuse, or start up the car. All these electrical problems are driving me nuts, hope somebody has an easy fix for this.
Old Mar 4, 2006 | 07:37 PM
Midnite 88's Avatar
Midnite 88
Can't help you but heres a bump 4 ya. TTT
