95 auto o/d problem
Old Mar 9, 2006 | 07:40 PM
aminnich's Avatar
aminnich
Default 95 auto o/d problem
I posted this on tech/performance this morning, got only one response, so asking here as well.
Everything seems to be working fine, recently serviced, and no codes. BUT also not shifting into overdrive. Is there possible reason other than internal in the transmission?
Old Mar 10, 2006 | 03:23 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I think it is the high presure Solenoid that is bad I think I spent about $75.00 for mine .Plus ,plus.Gaskets filter ans an "o" ring.
Old Mar 10, 2006 | 10:03 PM
aminnich's Avatar
aminnich
I have to get time to read thru my FSM tomorrow, but your suggestion sounds right. Trans shop is trying to sell me total rebuild and I think they are nuts. O/D seems to be always electrically controlled, I just need to find how it is done in my vette. If the electrics are working then it should be just an externally serviceable servo (solenoid). Thanks again for you input.
Old Mar 10, 2006 | 10:13 PM
Scott-89's Avatar
Scott-89
I don't want to hijack the thread, but this seems like the best thread to ask.
I have an 89 Auto with 44k miles and my OD doesn't want to stay engaged, or it seems that way. I have 2.59 gears and, on the highway it seems to lock up and unlock alot.
I have tried it with cruise control set at 60 and just staying at 60 without cruise and I get the same jumping back and forth.
Thanks for any advice.
Old Mar 10, 2006 | 11:05 PM
Pete K's Avatar
Pete K
Could be the solenoid. Could be a pressure switch in the valve body. Could be a valve in the pump hung up. Could also be the torque converter.
Old Mar 11, 2006 | 11:12 AM
redwing76's Avatar
redwing76
Take it in and have it checked at a good trans shop.
It could be any number of things. Chk the fluid 1st.
To 95 auto o/d problem
