Early next month I will be helping my folks move from WI to AR (goodie) and we need to tow the 86. Dad rented a flatbed trailer to be pulled behind the 24' rent-a-truck (should be strong enough ). This is through Budget and they said the trailer will be fine for a C4...I hope they are right. We were going to just do a dolly but the cost difference is not worth it.
Anyway, what is the recommended way to strap one of these puppies down for the 1k mile trek? I am also kinda worried about rock hits etc but I dont think there is much I can do about it. We are also towing a Buick Century too (same trailer) so any tips there would be helpful.
I noticed that there are little "ears" welded to the frame in the front and back. Are they strong enough to use for tying down? If not, then where else should we go to?
I would start by using the "eye'' holes plates that are already on the frame. In the front they are on the frame rails just behind the front tire. In the back they are a little harder to see , but on the frame rails ahead of the rear tire (if memory serves). I would use a quality tie down with ratchet ends either heavy duty nylon straps or the chain type. Make sure you have the car on trailer with the weight being somewhat balanced (I would go a little more forward with the weight). Get some "equalizing'' bars on the hitch to the trailer, that will help with handeling and the ammount of tongue weight on the hitch. Do not put a car cover on it, as that will beat the paint to death. Good luck with the move
Must be a big trailer If you put the weight in the rear of the trailer you will be all over the place with the trailer,put most the weight toward the front.
Did you ask at the rental place if they have suitable ratcheting straps? The rings you see in the front were used for holding the car on the transport when it was shipped to the dealer so those will work in the front.
In the rear, the slots in the frame corners will work; just remember to cross the rear straps: left side of the car to the right side of the trailer and vice-versa.
Don't know about the Buick but there should be some place where you can attach chains or straps to its body or subframe. The rear straps should be crossed too. How long is this trailer?? Towing two cars on a single trailer is a fair amount of weight to pull. It sounds like you will have about 7000 lbs of cargo on the trailer!
The trailer tongue weight should be 10% of the total trailer weight. The trailer should have a plate that shows the unloaded weight. Add the car weight to that and take 10% of that amount which will be the tongue weight. You also have to add the total towed weight to the trucks total weight (including your cargo) I would not put anything inside the car(s).
Don't use a cover on the car. The truck body will shield it from most road debris especially if the Vette is the forward car.
Oops...I should have mentioned that we are taking the cars on two trips... first the buick then the vette a few days later (or something like that). It is just a normal 1 car flatbed trailer.
I'll have to check on the tie downs they provide. If they don't have anything good, hopefully some of the local stores have some.
Thanks for the well wishes! Hopefully this all goes smoothly. I am closing on my first house about a week before all this so I get to store some of their stuff for awhile in my house/garage. HeHeHe...I get his Vette and his van along with all the tools/air compressors/MIG welder/etc.....It's tough helping family
Is th etrailor a 4 wheel one? If it is you should balance the weight. Measure your hitch height before car and it should drop an inch and a 1/2 for proper tongue weight. The weight distribution is very important for safety and handling.
If the trailer is a car hauler rented from Budget it should come with a set of tie down straps. Usually they have the type that wraps over the front tires.
As noted above, the rental car haulers usually have webs that wrap over the front tires and a safety chain in the rear. That's all that is needed.
I've trailered my vette on a uhaul carrier from AR to TX and from MT to IL with no problems. Probably the only worthwhile piece of equipment uhaul rents.
