Removing Sunvisor for head/viewing room (pics)
St. Jude Donor '05-'06,'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
I was swapping out the front mounting brackets a couple of weeks ago and I decided to leave the sunvisors off. Now without the visors there, the interior doesnt seem as packed or congested. I like the look. I never use the mirrors anyways
Anyone else run without them?
Here are a couple of pics...
I think *I* used them once or twice in the last 4 years. Now passengers are a different story
I've never used the mirrors either, but I really couldn't live without visors. Thinking about it now, I almost always have them down for the shade. It does look nice and clean, though.
I removed mine too. A lot more visible room. Like you I rarely used them. But make sure you keep them , I think for some odd reason you need them for a safety check.
They are really quick and easy to replace/remove so I'm keeping them around just in case.
Received 3,043 Likes
St. Jude Donor '05
Definitely cleans up the look inside. I should take mine off, never used them in 2 years, they do obstruct my vision a bit.
Mine were gone when I bought my 88 coupe. My wife wants one for her side so I just ordered a set. I'm not sure I want one on my side obscurring my vision since I'm 6' and she's 5' 2". I just see under the front roof now, no problem when driving into the sun. I'll try it and see.
I removed mine to.
Originally Posted by Admiral1
Wow, that does look clean.
Originally Posted by boudreaux601
Howd you do it? I think im gonna go try and take mine off right now. Im 6'6" and mine look pretty bad anyway. Ill be back.
Simple.
Remove your top. Take out the two small screws (see pic 1), and carefully remove the plastic cover. Once you do that you will be looking at something very similar to pic 2. If you look at where my finger is pointed, well that is where the visor holds into place with a srew and bolt. Simply undo and pull the puppy out. If you have the lighted vanity mirror undo the small electrical attachment that will be revealed once you start to pull the visor out.
PIC 1
PIC 2
Hope this helps
Location: Beyonce > Taylor Swift - Welcome to the good life!
1 Post
St. Jude Donor '07
Sorry for making you do the write up man. It took me all of 10 minutes to take mine off and I really like the way it looks now. Guess now i have a reason to go invest in a nice pair of glasses now. Ill load up my pictures later, chinese is callin!
No biggie man I took the pics for a write up Im going to make on swapping various year tops (84-E86, L86-88, 89-96) onto any C4
Glad ya like the look
I actually use them a lot when I have the top off. Sometimes they provide just the right about of shade when I forget (or can't wear) a hat. Looks great without them though...had me thinking about it for a minute or two.
