Well, I have a week off from work coming up and I'd like to flush the power steering fluid, brake fluid, and rear differential fluid. Can anyone give me the proper procedure and best products to use for power steering flush, brake flush, and rear differential flush? I don't want to screw it up. I've never flushed these three systems in a car before.
I use Valvoline Synpower for my brake fluid and power steering fluid. It is clear as water.
For the brakes, do yourself a favor and purchase a set of speedbleeders and the bleed becomes a one man job.
For the power steering, use a turkey baster and drain and replace with fresh fluid, turn wheel lock to lock, drain and replace and repeat one more time.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
To get the old fluid out of the diff, use one of those small fluid pumps backwards, add a longer tube to the suction side and stick that into the fill hole. If you're careful you can get most of it out.
The diff has no drain plug.
You can get a decent one at Harbor Freight tools for under $13. That's what I did.
