Window Tint Help!!!!
Old Mar 18, 2006 | 07:31 PM
Poncho C4's Avatar
Poncho C4
Default Window Tint Help!!!!
Well I'm getting my 84 ready to take out of hibernation
and I notice that the tint is starting to peel, I don't know how
old it is? since I'm the third owner! my question is, what is the
best & easiest way to remove the rest of the tint including the
rear glass without messing up the defrosting elements???
Thanks in advance.
Poncho.
Old Mar 18, 2006 | 08:09 PM
1994vette's Avatar
1994vette
YOu wont mess up the defrost elements. Just pull it off then spray windex with amonia and it will start to eat away the glue from the tint. You can use a razor blade on side ones and a hair dryer helps to get it off the back window.
Old Mar 18, 2006 | 11:08 PM
87vette's Avatar
87vette
On my old IROC vert I used to own, I used to spray warm soapy water on the side windows and wrap each of them in a garbage bag to heighten the humidity levels. It would help it to peel more and I could pull them off easier. Whatever glue was leftover.. I would use "sticker shocker" to spray on. It melts the glue and can be easily wiped off. You can find this at any parts stores.
Old Mar 19, 2006 | 09:54 AM
RRT vette's Avatar
RRT vette
I also found rubbing alcohol to work along with a razor blade.
Old Mar 19, 2006 | 11:02 AM
BRICHC4's Avatar
BRICHC4
I used spray adhesive remover and a razor blade, wish I would have had a heat gun when I did it, it was a pain in the A$$.
Old Mar 19, 2006 | 11:25 AM
obnoxus's Avatar
obnoxus
On the last two vettes I pulled the tint from the rear window.
The tint came off and left a glue residue. I sprayed it with Castrol superclean and the glue dissolved.
I covered everything with towels so it wouldnt drop into the car.
Worked well
To Window Tint Help!!!!
