wheel size question
Old Mar 20, 2006 | 10:01 AM
joe400's Avatar
joe400
Default wheel size question
I think i know the answere to this already but I'm going to ask anyway...
Can I use the same sized tire on 8.5" rims as on 9.5"? (I'm guessing NO)
I'm looking at some of the rims on ebay but nobody seems to offer 9.5 and 8.5 together to match the stock size and the size of my brand new Kuhmo's. I dont really want to buy new tires or spend $1000 for rims if I dont need to.
Thanks!
Old Mar 20, 2006 | 10:28 AM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I had 8.5s with 255s on the front of my 96. I bought 9.5" Z06 replica wheels and put the 255s on the front until they wore out. They worked. It is really easy to rash the lip of the wheels though, so be careful. When they were worn out, I replaced them with 275s.
Old Mar 20, 2006 | 10:37 AM
jrp's Avatar
jrp
Go to tirerack.com and look at the spec sheet for your tires. One of the specs will be a range of suitable wheel widths.
Old Mar 20, 2006 | 12:17 PM
MYCoupe's Avatar
MYCoupe
Well you didn't give specifics as to tire sizes, but here it goes. On the 8.5" you can use the 255/45/17 on the 9.5" you can use 255/45/17, 275/40/17 or 285/40/17 tires.
Old Mar 20, 2006 | 01:03 PM
mikeb's Avatar
mikeb
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
The 285s will also work with a 10" rim (10" usually for 300mm and wider tires)
Old Mar 20, 2006 | 03:17 PM
JCD's Avatar
JCD
275s fit fine on 8.5s, slight pinch, but only slightly more than 285s on 9.5s.
Old Mar 31, 2006 | 11:40 PM
joe400's Avatar
joe400
Thanks for the help!!! I kinda lost track of this post. Maybe had a few brewskis when I submitted it and just found it again.
I'm sticking with the stock 255/40/17 size. Just didnt know if they would fit on the wider wheel in the front. Is the extra inch that noticable on the fron or only when I smack the curb and people turn to look?
To wheel size question
