U-Joint question
Old Mar 20, 2006 | 06:31 PM
93txvette's Avatar
93txvette
Default U-Joint question
I am fixing to replace the u-joints in my car. I have a 93. The question is, i have called a couple places and one tells me that all six u-joints are the same and another place tells me there all the same. So which is it. And also they have some that are sealed and some that have to be greased. Which ones do i go for. Never thought buying u-joints would be such a pain. Hope its easier to change them than having to buy them.
Old Mar 20, 2006 | 06:34 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
They are not the same, not even close. The ones for the driveshaft (2) are Spicer part# 5-786X. The halfshaft ones (4) are # 5-800X. These are the correct sealed ones, they are stronger. They also have a special coating on them so they won't gall to the aluminum shafts.
Old Mar 20, 2006 | 06:41 PM
93txvette's Avatar
93txvette
thank you for the quick response. Guess people at the parts stores know less than i do, but atleast i am learning as i go. What a learning process.
Old Mar 20, 2006 | 06:52 PM
Corvette Kid
You're in a large market. If you can't find an auto parts store that can get Spicers, go to a truck driveline specialist who is a Spicer dealer. That's where I got mine and they were very reasonable, too.
To U-Joint question
