Good engine building book?
Old Mar 21, 2006 | 11:13 AM
bumpnzx3's Avatar
bumpnzx3
From: Edwardsville, Illinois 88 stroked s10, 92 stock 6spd
Default Good engine building book?
A friend of mine is looking to do a stock re-build on a small block and wants to do it himself. What's a good book that goes through each and every step in the engine building process- in order. He is mechanically inclined- but has never put an engine together. Any help would be appriciated.
Old Mar 21, 2006 | 12:20 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Is he interested in the LT (Gen II) or L series (Gen I) small blocks?
SA Autobooks has several books he might be interested in.
I think Eckler's has one on the LT.
Larry
code5coupe
Old Mar 21, 2006 | 12:26 PM
bumpnzx3's Avatar
bumpnzx3
yeah- guess that would have helped. it's an L series roller.
Old Mar 21, 2006 | 05:10 PM
Muffin's Avatar
Muffin
http://www.cartechbooks.com/vstore/s...ctGroup_ID=270
Check out these folks. Their rebuild book,SA26, is excellent. Haven't looked at the print/DVD version. As an aside,the remainder of their pubs are equally good.
Old Mar 22, 2006 | 12:03 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Believe it or not, JC Whitney still sells a video on rebuilding the small block chevy. I loaned my copy out but never got it back. I set our little TV/VCR up on my work bench and rebuilt an 81 Corvette engine into a real torque monster. I did all the work by watching what the mechanic did and then just duplicating the job. I was able to do all the work except the machining, freeze plugs, cam bearings and fitting the piston pins.
It probably cost me more than if I had just gone out and bought a crate motor with all the Edelbrock parts, but I had a ball! What a thrill to fire it up, hear it run and realize that I did it myself!
Old Mar 22, 2006 | 12:22 AM
DDSLT5's Avatar
DDSLT5
John Lingenfelter - Building the Chevy Small Block
Old Mar 22, 2006 | 12:28 AM
comp's Avatar
comp
Smokey Yunicks is good to have
To Good engine building book?
