Third brake light bulbs?
Old Mar 25, 2006 | 03:23 AM
nelson84's Avatar
nelson84
Default Third brake light bulbs?
Where would I get 86-90 vette rear third brake light bulbs, besides from GM. Has anybody seen them somewhere else and how much, and also how much from GM?
Old Mar 25, 2006 | 07:17 AM
PAINTER MAN's Avatar
PAINTER MAN
I got mine at the NAPA store. They do cost about 6 or 7 dollars a piece.
Old Mar 25, 2006 | 08:11 AM
Wayne88's Avatar
Wayne88
Bulb # 891, you can get them at most any auto parts store.
A little more expensive than most bulbs.
Old Mar 25, 2006 | 08:55 AM
mseven's Avatar
mseven
The dealer has them at about $12.87 U.S. each. and you need four of them. They will be more then regular bulbs in general because they are hallegens. I spent about 9. ea. from a regular auto parts. I would change all of them while you have it apart, usually if one goes the rest will probably be on their way. Be carefull on removal and install, as they have just 2 straight wires going into the connecter, very easy to bend etc.
Old Mar 25, 2006 | 02:26 PM
morgan_kane's Avatar
morgan_kane
It is just general 20w halogen bulb. You can use same 12v bulbs what many halogen lights have. Any electric shop will have them. I think i paid ~50cents each.
There also is different power specification bulbs. You can choose 15w, 20w, 25w etc. But don't take too powerful ones, they can melt your light...
Old Mar 25, 2006 | 04:08 PM
90Vettfan's Avatar
90Vettfan
Default Third Brake lite bulbs
Originally Posted by morgan_kane
It is just general 20w halogen bulb. You can use same 12v bulbs what many halogen lights have. Any electric shop will have them. I think i paid ~50cents each..
Are you saying that you need NOT replace with $$$$Halogen bulb but can use a standard bulb (peanut style) in same Watt and size? Do you know what the bulb # would be in a standard bulb?. I do believe that a standard bulb would throw enough lite to make it sufficiently bright...especially with 4 of them. Halogen or regular, I would just be happy with all the lites working..despite halogen or not and save the $$ for something more important than an "overpriced" lite. Let me know if you have the # for the bulb..thanks...90Vettfan
Old Mar 25, 2006 | 11:25 PM
rodj's Avatar
rodj
Had same prob as you here in the colonies.
Check the lighting dept of any dept store.
Usually replacement for halogen desk lamps.12V
Pins same size but a little wider spaced , squeeze closer and insert.
I have 50W in mine - super bright and not on long enough for heat build up.3 years , no probs
To Third brake light bulbs?
