Need Seat Advice
Old Mar 25, 2006 | 04:23 PM
Fast Cop's Avatar
Fast Cop
Default Need Seat Advice
I have a 96 vert with standard seats. The drivers seat is in very good condition and the passenger seat looks brand new. I was thinking (first mistake) that I could change the dirvers seat with the passenger seat as I believe they are interchangable. Any advice or has anyone done this, if so results!!!! Thanks
Old Mar 25, 2006 | 04:37 PM
86PACER's Avatar
86PACER
Guys do it all the time. Go for it. I don't know about yours, but the early seats cushions are only held in place by metal clips. No tools required.
Old Mar 25, 2006 | 04:44 PM
champs65's Avatar
champs65
Just did this on my 85 (not sport seats) and they are 100% interchangeable. I just switched the pads as my driver seat is power and the passenger is not. The bottom is a snap without removing the seat assembly, but I think the back is easier by pulling the seats out of the car. Gives you a good chance to do a nice cleanup of the carpet, too. My guess would be that with sport seats the lumbar controls it would work too but take a little bit of getting used to with the switches being in opposite positions
nutz4c4's Avatar
nutz4c4
Rotate 'em
Old Mar 25, 2006 | 04:45 PM
86PACER's Avatar
86PACER
A while back someone here posted a short video clips showing the removal of the seat cushions. I can't find it though.
Old Mar 25, 2006 | 07:13 PM
Fast Cop's Avatar
Fast Cop
Thanks for the advice, I now have a short project for tomorrow that I can get done in the morning and watch the race in the afternoon.
Old Mar 25, 2006 | 07:35 PM
corvette1989bham's Avatar
corvette1989bham
HOLD ON............94 to 96 seats are different than prior years. Up to 94 you can unclip the tops and bottoms and swap side to side....very good to do. The later years the backs DO NOT unclip, they are part of the seat back.Must unbolt the back seat frame, remove the recliner cable etc...and THEN I am not sure the bolts patterns are the same on left and right...check on that before you start your project and post your results please!
Old Mar 26, 2006 | 04:07 PM
Fast Cop's Avatar
Fast Cop
Yes you are correct sir. I just completed the task and only changed the bottom cussion as that was very easy. The next time I pull the seats out for carpet cleaning I will change the backs.
Old May 10, 2006 | 10:45 AM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
How do you just swap out the seat bottom cushion for a 95? How does it come out, driver vs passenger etc?
Old May 10, 2006 | 03:31 PM
bryantbjb's Avatar
bryantbjb
Originally Posted by nutz4c4
Rotate 'em
I do it to spread the wear around.
To Need Seat Advice
