shifter console
Old Mar 26, 2006 | 04:04 PM
1996man's Avatar
1996man
Default shifter console
my consolei is falling apart near my shifter. my boot is coming loose from the plate as well and the plate itself is cracked. where is the best place to buy another set and about how much money am i looking at?
Old Mar 26, 2006 | 05:23 PM
kize's Avatar
kize
Your typical vet parts places have them. Cost is the usual 10.00 plus 100.00 corvette tax.
Old Mar 26, 2006 | 08:31 PM
87vette's Avatar
87vette
Check on ebay. I recently got one new for an auto for $93 dollars. The corvette catalogs charge twice that!
Old Mar 27, 2006 | 06:54 PM
1996man's Avatar
1996man
anybody else?
Old Mar 27, 2006 | 07:05 PM
Soggytaco's Avatar
Soggytaco
I bought a used one from someone on this forum for $90 or you can go with zip products about $140 look in the C4 parts section I know someone is parting out a 96...
Old Mar 28, 2006 | 12:54 AM
bryantbjb's Avatar
bryantbjb
Just did mine and the cost was $100.00 from The Last Detail. When you remove the center plate keep the shifter boot little metal caps that hold the shifter boot screws. That was my only disappointment - removing the little metal caps and reattaching. It appears that they use these so the screws do not have to touch the console plastic. It was a PITA to remove the screw caps. GM must have glued them on and then crimped them. You will see when you remove. Just don't lose any of them.
Old Mar 28, 2006 | 06:18 AM
sonny1974's Avatar
sonny1974
I still have my old one is not cracked you can have it 95 auto
Old Mar 28, 2006 | 11:12 AM
1996man's Avatar
1996man
Im sorry i replied to your PM before i read this post. Thank you very much for the offer but mine is a manual and i dont think it has the slit cut in it for the gear display like yours does. thanks again
Old Mar 28, 2006 | 11:40 AM
tlong's Avatar
tlong
I bought mine at TLD but.....
There are 2 kinds. One is aftermarket for $100, the one I tried. The Dulco finish scratches if you look at it sideways. The ash tray hinge is semi broken.
The 'good one' from GM was $170. My old one looks better after 10 years. Get the good one.
Old Mar 29, 2006 | 12:32 AM
yellowlust's Avatar
yellowlust
I haven't looked at the one I got from TLD (not GM). Need to put it on one of these days.
Old Apr 17, 2006 | 08:05 PM
1996man's Avatar
1996man
anybody have a part number? im curious how much gmpartsdirect wants
To shifter console
