does anyone know the answer???
Old Apr 8, 2006 | 10:22 AM
vetteboy88's Avatar
vetteboy88
Default does anyone know the answer???
I want to replace the shocks on my 1988. Looking at the bilsteins. Currrently have KYB's, which were on the car when I purchased it. Looking more for ride than performance. I can't seem to determine what suspension I have. I have no labels on console door, door jam, springs, etc. I have 17" tires, but again, these were on the car when I bought it and don't know if they were stock. I believe it is a base coupe, but want to be sure before I take the plunge. Any help would be greatly appreciated.
Old Apr 8, 2006 | 10:28 AM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
your RPO code listed on the Service Parts Identification label will hold the answer.
It is a white label in the center armrest (underside) - open it up and see if you have Z51 or Z52 which would indicate for sure it came with Bilsteins.
Code FG3 was for Bilsteins, by themselves - I hope this helps
http://www.corvetteactioncenter.com/...88/88prod.html << this link gives the 1988 codes & production for each
rick lambert's Avatar
rick lambert
My sheet is under the console lid-surprised it's still there after so many years. As far as shocks go, I'll probably replace the Bilsteins with KYBs, I don't like the stiffness of the Bilsteins.
Old Apr 8, 2006 | 10:29 AM
*89x2*'s Avatar
*89x2*
...there are of course, different Bilsteins you know, right??
Old Apr 8, 2006 | 10:46 AM
rick lambert
Maybe so, but for the $$$$$$$$ I'll go with the KYBs, most guys using them like them, if you're doing cross country, then Bilsteins have the advantage-softer ride KYBs.
Old Apr 8, 2006 | 11:01 AM
cv67's Avatar
cv67
St. Jude Donor '05
If youre looking for a more civilized shock try the Edelbrock IAS. THe KYB's are pretty stiff, trust me. One reason why I carry a screwdriver in the 89
Old Apr 8, 2006 | 12:47 PM
vetteboy88's Avatar
vetteboy88
As I said, my console must have been replaced and doesn't list the rpo codes. Am I screwed????? I will be looking into the edelbrocks though.....
Old Apr 8, 2006 | 07:25 PM
JeffM1243's Avatar
JeffM1243
88 base suspensions had the 16" wheels, base steering rack(2 & 1/3 turns lock to lock), 1 radiator fan, and no oil cooler.....
The Z-52 suspension had the 17" wheels, the second radiator fan, the engine oil cooler (spacer above the oil filter w/ cooling lines running from it) and the quick ratio steering (2 turns lock to lock)....In addition the front swaybar was 26MM....
The Z-51 suspension had all of Z-52 & upgraded the swaybar to 30MM and the front rotors to 13"...In addition Z-51 was only available w/ manual trans......
Old Apr 8, 2006 | 11:44 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
- besides having to cut the front shocks off, I thought the car rode like a brick with the Bilstiens. I have the Z52 suspension. I got a set of shocks from Auto Zone for $20ea, & the car rides great. I think they are Gabriel Gas Riders, if I remember right.
Old Apr 11, 2006 | 12:25 AM
Lichen's Avatar
Lichen
I've had both, and the Bilsteins are 100x better when it comes to high-speed cornering. If you want a soft ride, buy a Buick.
Old Apr 11, 2006 | 08:04 AM
runner140*'s Avatar
runner140*
I have KYB's in the front and Bilsteins in the rear. Good combo for me.
Old Apr 11, 2006 | 09:31 AM
mseven's Avatar
mseven
The fx 3 in mine is way tight and rides hard......I don't care, but if I were planning on putting some real miles on it, about 2 or so hours is all I can stand, I've gotten soft in my old age
Old Apr 11, 2006 | 12:15 PM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
vetteboy88, don't you just love it when you post "I have no labels on console door, door jam, springs, etc." and the first reply you get says to look at the label under your console door?
If you go to the Corvette Museum web page https://store.corvettemuseum.com/ser...buildsheet.asp you can order a build sheet and original window sticker for your Vette using your VIN. With the build sheet you will have all RPO codes for your Vette as it was built at the factory. Both the build sheet and the window sticker have the RPO codes, but the build sheet has more GM internal plant info about your car.
I've had KYB, Koni Sport, and Bilstein Z51 on my Vette and I prefer the Bilsteins over the others by a wide margin. That is my personal choice however. You said you were "Looking more for ride than performance." Stick with the KYB then. Much softer and more "cushy" than the Bilsteins. Cheaper to replace too.
A lot of the ride quality is due to the tires. Ask around about the best riding tires currently available and look into improving your ride quality that way too. I replaced my GSCs with Firestone FireHawks and the ride and perfromance both improved. You don't have to give up ride quality for performance when it comes to tires.
Old Apr 11, 2006 | 03:47 PM
mikey whipreck's Avatar
mikey whipreck
FWIW, Besides the wheels, you can't really tell what suspension you have by the other components on your car.
My '85 has dual cooling fans, 3.07 rear end, oil cooler, etc... but it's not a Z51.
There is usually a build sheet attached to the gas tank, if you didn't check there.
In any case... I put KYB's on mine a while ago, and I like them. Much improved ride.
Old Apr 11, 2006 | 04:34 PM
81c3's Avatar
81c3
I can comment on the individual brands themselves, but I have had them on cars other than the Vettes. I had KYB's on my Z28.....way too stiff. I switched to Koni Reds...(adjustable), these worked well on the Z28. I had regular Gabriels on my 89 Coupe......too soft, especially up front. I went to Bilstiens...Excellent all around. Now, I have the AC Delco's on my 94 Vert....they suck. Too soft again. I will be getting another set of Bilstiens on it soon.
Old Apr 11, 2006 | 06:35 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
My 85 is an automatic equipped Z51 car. It has the code on the console door, the 3:07 gears and the auxilliary cooling fan. A Z51 car has quicker steering so turn your wheel lock to lock and count the turns. Two turns is a Z51, two and a half or more is the other suspension.
To does anyone know the answer???
