Which gas ???
Apr 10, 2006 | 11:02 AM
Which gas ???
I am sure this was asked before so i apoligize in advance. I have an 89 vert stock do I or should I run high octane gas. Thank you for all the help.
Apr 10, 2006 | 11:11 AM
I run 92 octane (Exxon preferably) in my 96 Vette. Anything lower will make the valves "knock".
Apr 10, 2006 | 11:16 AM
92 or better in my '92 here. I have one of those Hypertech chips that a lot of people say is a waste of money, the manufacturer's info said thats all you can run with their chip.
Apr 10, 2006 | 11:36 AM
St. Jude Donor '05
I run 87 unless Im going to the track.
Apr 10, 2006 | 09:16 PM
My manual for my '88 says min 91.
Apr 11, 2006 | 02:09 AM
2015 C5 of the Year Finalist
St. Jude Donor '07-'08-'09
im my 96 it says either on the dash or under the fuel dor "premium unleaded fuel only" It also says it in the manual
Apr 11, 2006 | 09:46 AM
87 in my 87 for the past 7 years. Run the lowest octane you can without pinging.
Apr 11, 2006 | 10:12 AM
I think L98's only need 87 and nothing higher, but it might depend on whether or not it has aluminum or iron heads. LT1's probably need a higher grade due to the higher compression ratio.
Jun 15, 2006 | 12:58 AM
my 1986 manual says run 87
Jun 15, 2006 | 03:17 AM
Jun 15, 2006 | 07:11 AM
I also run 92 octane in my 92, but I buy from the cheapest gas station I can find .
