Auto Trans Problem
Old Apr 10, 2006 | 12:58 PM
z528e's Avatar
z528e
Default Auto Trans Problem
Took My Car Out For A Ride On Highway Kicked It Down A4 And Got Some Slippage. I Then Lost 3rd Gear And Overdrive. My Car Has 68000 Miles Could This Be The Electronic Ignition Or Do You Think The Tranny Is Gone . Help Would Be Appreciated.
Old Apr 10, 2006 | 01:14 PM
Jet-Jock's Avatar
Jet-Jock
Don't know much about the electronic transmissions but have you checked the automatic transmission fluid level with the engine hot and with the car level?
Old Apr 10, 2006 | 01:19 PM
jeffyc's Avatar
jeffyc
chances are the 3/4 clutch pack is gone
Old Apr 10, 2006 | 01:20 PM
Pete K's Avatar
Pete K
The 3-4 clutch pack is notoriously weak on these transmissions. The failure you have is typical. The 3-4 pack can be upgraded during the rebuild to help prevent this in the future.
Old Apr 27, 2006 | 11:11 AM
84vette96's Avatar
84vette96
I have a simular prob. on my 96. in two seperit trans 3rd and 4th went out at same time. they both had a slow 2 to 3 shift.I am not sure if I have bad luck with transmitions or if I have a comp. or wirering prob. with the car. It seems strange two differant trans. would break the same way without something causing it.
Old Apr 27, 2006 | 11:58 AM
jeffyc's Avatar
jeffyc
as pete k said the 3/4 clutch pack is weak
it could just be back luck for you that it happened to 2 of your vehicals at the same time
you have checked the typical stuff like fluid right?
is it burnt?
if they need to be rebuilt then make sure u get a HD 3/4 clutch pack
the 3/4 pack that was in my truck and vette had 6 frictions
they now have 8
Old Apr 27, 2006 | 01:23 PM
84vette96's Avatar
84vette96
It looks like i did not make my self cleer. It was two difirent trans in the same car. When I put 2nd trans in the car it also had the bad 2 3 shift. and both lost 3rd and4th driving on highway at 60mph crusing.I hope this was a little better.
To Auto Trans Problem
