u joints
Old Apr 11, 2006 | 04:09 PM
Buttz's Avatar
Buttz
Default u joints
does anyone know if u joints out of a newer c4 will work in a older c4? My buddy has a set he never put in his 95 and I need them and have a 87. thanks
Old Apr 11, 2006 | 05:17 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
All C4s are all the same for U-joints.
Old Apr 11, 2006 | 05:37 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Are the drive shaft U-joints the same as the axles?
Old Apr 11, 2006 | 05:40 PM
Corvette Kid
No, the axles take a larger joint than the driveshaft. The Spicer numbers are 5-800X for the halfshafts and 5-786X for the drive shaft. Four and two required, respectively.
Old Apr 11, 2006 | 05:42 PM
jrzvette's Avatar
jrzvette
thanks
note to Buttz -make sure you get the correct ones.
Old Apr 11, 2006 | 06:37 PM
Buttz's Avatar
Buttz
so the ones for the driveshaft are interchangable but on the ones for the axles?
Old Apr 11, 2006 | 06:39 PM
Corvette Kid
Yes.
Old Apr 11, 2006 | 07:48 PM
Jet-Jock's Avatar
Jet-Jock
How difficult is it to change these guys out?
To u joints
