Door panel fix
Old Apr 12, 2006 | 09:56 PM
Gazpar's Avatar
Gazpar
Default Door panel fix
Idea for the moderators/Mojo:Can there be a stickey on DIY fixes, with links. Im seeing more and more REQs for older writeups, that get lost in the FLOOD of info that passes through here.
The reason for this suggestion is:I recall seeing a very nice post about how to fix the door panel rattles, using an L-Bracket, and some other stuff.
Ive done a search (several times), and am unable to find it.
If its been archived, how can I find it?
GREAT INFO here Thanks all
Old Apr 12, 2006 | 10:36 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Try the C4 tech tips section:
https://www.corvetteforum.com/techti...=242&TopicID=2
Index:
https://www.corvetteforum.com/techtips/
Old Apr 12, 2006 | 11:10 PM
Gazpar's Avatar
Gazpar
OMG!
Thatis JUST what I was looking for..
Old Apr 13, 2006 | 05:17 PM
Blue 92's Avatar
Blue 92
Originally Posted by Gazpar
OMG!
Old Apr 13, 2006 | 05:22 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default It works...
Just make sure that you put them on like this.
Passenger side example:
L - The "L" bracket"
Top of Door
(<<<inside of car)
if you do it the opposite way the window will rub.
Yeah I can't follow directions and had to reverse mine.... Live and learn.
To Door panel fix
