i sold my house a couple of weeks ago, (it sold in three days and i got full price )
i am going to build a new garage in the next couple of weeks at the new place, nothing too big, probably 20x24ish, with scissor trussus for a little more head room. anyways...i am going to build new cabinets, the lumber yard had a pile of black malemine laying around, they sold me 40+ sheets for only $150, i couldn't pass that up and black cabinets will look cool. here's my question, usually when i have build work benches, i have used solid core wood doors for my counter tops, they are super strong and will take a beating, however they don't look to nice after a while, painting them makes them look even worse after a little use on them. and then tend to burn when welding on them.
what have you guys used for tops?
if anyone has any ideas for any "must haves" for the garage, i already have a big screen tv and a beer tap setup going in, let me know.
thanks
I used some left over cabinets when I built my house. For a countertop, I just went to Home Depot and got the pre-made formica top with a turned edge and built it backsplash. I beefed it up underneath and it's pretty solid. A friend of mine found a butcher going out of business and and bought lengths of solid wood butcher block. I've never seen anything more solid than that! Here's my set up:
Whatever you do, don't build a garage as small as 20x24. You'll hate yourself for it later. 24x24 is the absolute minimum for a 2-bay garage, and larger in either/both directions is better still. At the very least, go more than 24 deep to allow plenty of room for workbenches, tool cabinets, compressors, etc.
Be well,
SJW
I tend to agree with that. Even an extra foot of width is much appreciated when parking two cars side by side. (Especially if a truck is one of them)
The length allows you to work on a workbench without having to remove a car first. Mine's 24x26 because the builder in my subdivision built this house for his daughter. Most of the rest are around 20X20.
From: The reason time exists is so everything doesn't happen at once
I used solid core flush doors for my workbench top. I covered them with 1/4" hardboard (masonite) using 3/4" wood screws (countersink the heads). Then I trimmed the edges with 1x2 maple. When the masonite gets too beat up or looks ratty I just take out the screws and replace the top.
When I had the garage built I had the builder add an additional 3' to one side (21x26) so I had room for the workbench.
Be well,
SJW
SJW is right, do not build a 24x20 garage, it will only cost you 5% or 10% more to make it large enough to have room for all the ancillary stuff you will definitely need. If you can afford it build a 3 car garage, but if not make sure you build an "oversize" structure. A 24x20 will only house 2 cars.....just, with no room to spare for anything else. Minimum would probably be 24ft deep, and 28ft wide. That extra 200 sq ft will make all the difference. My garage is slightly "L" shaped, 20 wide and 22 deep, with a 10x10 "alcove" which is ideal for my 8ft bench and parking for 2 motorcycles. With 2 storage cabinets in the main part of the garage, once I get 2 cars in there the place is full. My plan is to extend the garage and make it a 4 car garage. Spend that bit more and make sure your garage is big enough, you will regret it afterwards if you don't.
back yard space will only allow a 20x24 garage
this house is only temporary, i plan on building a new house next year, at that point i will pull out all the stops and build my permanent garage.
the garagejournal.com site is great, i signed on last week
Well, that sorta limits things then. I guess you'll have to go with the 20x24.
You could always tell the wife she has to park her car outside until you build the new house.
The solid core doors are really good for this, and I would agree with adding the 1/4" hardboard to it with screws, so it can be replaced when it gets bad. The Hard Maple edging will wear better than most other woods.
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
The clinic I worked at replaced the metal ambulance entrance door with a new one. I asked permission to have it and they gave it to me for free. It was a bit wide so I cut it down with a carbide blade in my skil saw. I mounted in on 4X4s and can beat the living crap out of it with no problems. The only drawback is that I had to fill in the hole used for the "peephole". If you have a place that recycles building material then you might be able to find one like it.
