I have fit on my 84 Vet C4 was going to replace my original tires and rims with 295/45zr/18 10 inches wide. and front 245/45zr/18 and 8.5 wide? I got a good price on some 06 tires and rims from a 06 Vet.
84 - 87 had a different offset than 88 on Vettes. I would talk or call the the guys at your local Discount Tire(They know their stuff) and most likely they can tell you whether it will work or not.
The value of those wheels actually may be worth enough that you could sell them, get a real nice set of aftermarket wheels, and you'll know they'll fit. This is assuming that they won't fit, because if they do, use them, as it would be a real unique look.
Yep, I have an '85 and can tell you the offset is different. You will need spacers for sure. I dont even think that big of a wheel would fit without sticking out about an inch.
Well I bought the rims and the front ones fit perfect. I need a 1/2 inch spacer in the back and they look really nice.. I will take a picture and post. I got all 4 rim/tires are nitto brand and they are brand new. for 900.00.
no they will not fit... i think the spacing is way off.
My bro-inlaw has the "ZR1" wheels (11's in back wooo!) on his 84...they were some special spacing (check ebay for "84 corvette wheels rims" and you will see what I mean)
If memory serves me correctly,I think the offset on the early C4's was +38MM and the later offset was +56MM. Doesn't seem like a lot, but believe me, there's a big difference...I speak from experience.
Well vet buddies they worked. I had to add spacers in the back but the front where fine. I took the my sweet Vet out after I installed and was a very nice drive/smooth ride and it looks GREAT I will post some pics this weekend.
