What is this?
Old Apr 14, 2006 | 04:12 PM
MNorlander's Avatar
MNorlander
Default What is this?
I have seen this a couple times before, and I'm not very mechanically inclined. It is right behind the driver seat underneath a layer of insulation under the storage box.
Old Apr 14, 2006 | 04:30 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Control unit for the ABS Brakes
Old Apr 14, 2006 | 04:31 PM
86PACER's Avatar
86PACER
That is your ABS Modulator Valve (pump) and the ABS Control Module (computer). If your ABS works, that is where that spinning sound comes form when you start the car and reach 4MPH.
Old Apr 14, 2006 | 08:47 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
On my `87, it only makes a little noise when I put it in reverse for the first time in the morning. No noise at all, the rest of the day.
Old Apr 14, 2006 | 10:52 PM
86PACER's Avatar
86PACER
Interesting. Shop manual says it should do it every time the car is shut off and 4 MPH is reached again, as it's a "check" the ABS system runs on itself each time. My 86 does.
Old Apr 14, 2006 | 11:30 PM
Jet-Jock's Avatar
Jet-Jock
yep the noise you hear is the valve cycling. All the senors are checked and the valve cycled.
Old Apr 15, 2006 | 01:19 AM
Ericsvette's Avatar
Ericsvette
Interesting. I always thought that noise was coming from my rearend. I'm talking about the rearend on the car of course.
Old Apr 15, 2006 | 01:21 AM
Fast Cop's Avatar
Fast Cop
Its the space control unit. When you want to jump into light speed just open up the valves tothe fully open position and you are ready to go. OK its the ABS control unit.
Old Apr 15, 2006 | 10:59 AM
vetteboy88's Avatar
vetteboy88
Hmmm. My 88 only does it on the first start up, when backing up......
Old Apr 15, 2006 | 11:13 AM
gigaglytch's Avatar
gigaglytch
Oh, ABS. I always thought that was the fuel pump. OK.
Old Apr 15, 2006 | 12:49 PM
Jet-Jock's Avatar
Jet-Jock
If you go quick enough yes reverse or forward doesn't matter.
Old Apr 15, 2006 | 01:12 PM
Yakko's Avatar
Yakko
I assumed it was the ABS. Mine, too, does it first thing when I back out of the driveway. I''l listen closer at 4mph.
To What is this?
