window opening
Old Apr 18, 2006 | 03:36 AM
vuk8691's Avatar
vuk8691
Default window opening
Hi!
I've got c4 1995. Yesterday, when I tried to open passinger's window, nothing happens!
Driver's window works normally.
What could be a problem?
P.S. Sorry for my bad english.
Old Apr 18, 2006 | 03:41 AM
Chance's Avatar
Chance
From: I was a young troubadour when I rode in on a song, and I'll be an old troubadour when I'm gone.
St. Jude Donor '08
Hmmm....
The switch may have gone bad. That is not an uncommon problem.
I'm not sure of the best way to test the switch or replace it, though. Maybe someone else can help you out.
But if the motor doesn't run and nothing happens at all, the switch may have failed.
Old Apr 18, 2006 | 03:59 AM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
What about the switch on the passenger door?
Old Apr 18, 2006 | 10:41 AM
jabez's Avatar
jabez
Originally Posted by vuk8691
Hi!
I had a bad motor on mine. I took it to a repair shop and it cost me 300 bucks to fix.
Old Apr 18, 2006 | 11:08 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
ummm where did my post go?
it was useful and informative of common window issues...
*** Doh! never mind.. i see he posted this topic in 2 places...
Old Apr 18, 2006 | 11:27 AM
Tommy T-Bone's Avatar
Tommy T-Bone
St. Jude Donor '06-'07-'10-'11-'12-'13-'14
Press your window switch with the key in the on position and look at the voltmeter on the dash. Is the voltage going down when you apply the switch ? If the voltage is changing it's probably the motor. I picked up an oem motor on ebay for $45. and talked with a local auto glass shop owner to see what he would charge. ( $100 was what he quoted me). The motors are left and right so make sure you get the correct one. Good luck on your search.
Old Apr 18, 2006 | 12:08 PM
Chance's Avatar
Chance
St. Jude Donor '08
Well, that's unlikely.
To window opening
