From: I live at www.domesticlugnuts.com I sleep in PA
Oil Coolers
What kind of oil cooler are you guys using and what decrease in temps did you see after the install.
I have ran my Modified 84 on a couple of state to state runs and on a 70 degree day I have a coolant temp of 178 to 184 and an Oil Temp of 243 to 248. This is just normal cruising at 75 to 80 mph.
I would like to see the oil temp down in the 210 to 220 area.
The stock cooler on my 87 gives me the temps you describe(200-220). No doubt that an aftermarket air type cooler would be a better option. Because I have mine already, I kept it.
I removed my cooler when I freshend my engine and temps climbed 20-30 degrees without it (approx 250 on a hot day). I plan to reinstall it soon.
