battery replacement
Old May 1, 2006 | 02:44 AM
camaroneil's Avatar
camaroneil
Default battery replacement
guys,
my buddy has just got an 86 greenwood,
it needs a new battery and i can't see how the side panel will come out as it's moulded onto the side skirt,
am i missing something here????
i'm used to c3's not c4's,
thanks,
natt
Old May 1, 2006 | 10:31 AM
Red Dwarf's Avatar
Red Dwarf
http://www.corvettemagazine.com/2001...ttery/bat1.asp
Old May 1, 2006 | 10:35 AM
c4cruiser's Avatar
c4cruiser
You may have to remove the entire side skirt if the lower gill panel is part of the skirt. There should be some screws along the panel under the car.
Old May 1, 2006 | 10:51 AM
89sleeper's Avatar
89sleeper
From: The land of 10,000 lakes ,Minnesota 89 coupe 6speed with 383 and 89 roadster 6speed bonestock with XXX low miles
: Remove the three torx screws along fender well and remove the 10mm screw/bolt on the top of fender and the 10mm screw/bolt just loosen a couple turns the hole is slotted on the bottom so you do not need to remove the screw/bolt
Old May 1, 2006 | 11:01 AM
RRT vette's Avatar
RRT vette
The 3 torx screws are behind the tire on the fender well. Ther is one 10mm behind the battery that hold the fender in place and also is used for fender adjustments. The other 10mm bolt is directly under the first 10mm and is between the fender and rocker panel and a small 10mm wrench is needed to just loosen (probably have to get on the ground to see)...this also is used for fender adjustment.
Old May 1, 2006 | 11:54 AM
camaroneil's Avatar
camaroneil
thanks guys,
will give it a go tomorrow,
natt
To battery replacement
