Door Hinge
Old May 2, 2006 | 09:14 PM
qws's Avatar
qws
Default Door Hinge
On my 84, drivers side door there is about 1/2 inch of play or so. In order to get it shut all the way you have to lift up a bit. I was looking through my FSM and they talk about replacing the door hinge, but I don't see where or how you can adjust it or even tighten it. Would I need to replace the hinge or is there just some grommets or something I need? An suggestions would be helpful.
Old May 2, 2006 | 09:34 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
the hinge, or the spring?
Old May 2, 2006 | 09:50 PM
aminnich's Avatar
aminnich
I thought that was just a matter of replacing the pin and bushings.
Old May 2, 2006 | 10:02 PM
qws's Avatar
qws
I went out to the garage again and it seems like the play is in where the pins are.. is this replacable without buying the whole hinge? Where can I get it? thanks again
VinceC4's Avatar
VinceC4
Default probably the hinge
I think the hinge is probably a bit worn where it is bolted to the support. either the hinge or the support itself is probably a little rusted and the mounting holes have enlarged..most likely you will need to pull the door and do a real close inspection
Old May 2, 2006 | 10:05 PM
aminnich's Avatar
aminnich
Pin bushing sets are about $10 from almost any auto parts store, or even on ebuy.
Old May 2, 2006 | 11:43 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
I have Gordon C4 Bloomington Door repair guide, and can PDF if anyone would want a copy, just email me.
Old May 3, 2006 | 02:16 AM
Demonic85's Avatar
Demonic85
I've got experience with this. You'll need to have the hinges rebuilt or get new ones. It will only sag more until you cant close the door at all... (maybe)
Old May 3, 2006 | 06:44 AM
qws's Avatar
qws
I'm gonna stop at the auto parts store today and see if they have a pin bushing set. The hinge supports that bolt to the door and the body seem nice and tight. There isn't any rust or anything and overall seems to be in real good shape, so hopefully they have just this pin bushing set
thanks guys
Old May 3, 2006 | 01:06 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Might be a good time to mention that lubricating high-wear items like door hinges should be undertaken every time the oil/filter is changed.
It will do a lot towards keeping your car in like-new condition.
(There is a reason the FSM's have a three-page-long list of lubrication items in the Maintenance Schedule section)
Larry
code5coupe
Old May 3, 2006 | 03:02 PM
DRAKEFAMILY2's Avatar
DRAKEFAMILY2
I am in the process of replacing my hinges on my 84. From what i've went thru so far i think the easiest way is to leave door shut and loosen the bolts on the door side of top hinge( the top door hinge has nuts on the inside of door on my 84, remove door panel and remove nuts from inside door) then remove bolts from body side of hinge, then slide complete hinge out. If you open hood and remove the lower fender its pretty easy to get at hinges. All the rest of hinge bolts on the bottem have a plate so you can remove all the bolts no problem. I don't know if someone lost the plate on my top hinge or what. I tried driving out the top hinge pin but that is very tricky and hard to do, thats why i'm removing whole hinge. If you have any questions let me know.
Old May 3, 2006 | 04:17 PM
qws's Avatar
qws
Where did you pick up the hinges?
Old May 3, 2006 | 06:35 PM
DRAKEFAMILY2
I bought them off ebay, used but nice shape. Theres also a guy selling all 4 pins and bushings for $14.40. These are new, item 8060417185.
To Door Hinge
