Resetting Oil Message
May 3, 2006 | 01:47 PM
From: www.ncminsurance.com Bowling Green KY Home of the Corvette!
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
St. Jude Donor '07-'08
How does one reset the "Change Oil" message?
I know I should know this!
Thanks!
Adam
May 3, 2006 | 01:56 PM
oh, god... what a pain...
lemme see if I remember...
press and hold gauges for 5 seconds or something like that
release gauges, press it again... I think it's at this time something flashes, but I don't remember
then, press the Eng/Met button and hold it... then the change oil light should flash... it takes 10 seconds of holding for this to reset.
I THINK that's the process.
May 3, 2006 | 02:02 PM
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
1 Turn the key to the "ON" position, but don't start the engine.
2. Press the ENG MET button on the Trip Monitor and release it. Then, within five seconds, press and release the ENG MET button again.
3. Within five seconds, of Step 2, press and hold the RANGE (1990-1991) button or the GAUGES (1992-1996) button on the Trip Monitor. The CHANGE OIL light will flash.
4. Hold the RANGE or GAUGES button until the CHANGE OIL light stops flashing and goes out. When the light goes out, the Engine Oil Life Monitor is reset. This should take about ten seconds. If it doesn't reset, turn the ignition "OFF" and repeat the procedure.
May 3, 2006 | 02:03 PM
From: The reason time exists is so everything doesn't happen at once
May 3, 2006 | 02:10 PM
From: First to Sign Grumpy's Hat Only 53 miles from Hell
St. Jude Donor '06-'09-'10-'11
Quote:
Originally Posted by jrzvette
May 3, 2006 | 02:57 PM
yea... knew I had screwed that process up...
May 3, 2006 | 03:06 PM
Quote:
LOL! Thanks for being the first to try!
Adam
May 3, 2006 | 04:05 PM
I think ive only done that oil reset thing once since i've owned my car. I always forget
