Abs Light
Old May 7, 2006 | 08:43 PM
1blkc4's Avatar
1blkc4
Default Abs Light
Just Replaced Two Front Wheel Hub Assy. On My 94 And Now My Abs Light Comes On Only When I Come 2 A Stop And You Can Here The Abs Motor To. Any Suggestions ?? Maybe Deffective Hub ?
Old May 8, 2006 | 04:18 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I would try cleaning the sensors up front,with alchol.
Old May 8, 2006 | 08:07 AM
morgan_kane's Avatar
morgan_kane
I have same problem after changing front bearings. I haven't found cause yet. I maybe try to change old bearings back and test, if that helps. Then i even know, if both or only one is defective.
To Abs Light
