Front end alignment
Old May 10, 2006 | 11:16 AM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
Default Front end alignment
I would like to find out what front end alignment procedures or maintenance is needed for the C4. I have a 95 VERT, stock front end. Is there something that should be done routinely for alignment?
Old May 10, 2006 | 11:39 AM
aminnich's Avatar
aminnich
Not just front end alignment, all 4 corners should be aligned at the sametime. This is not a maintenance issue that needs to be done every so many miles, but if you feel vibration, pulling, drifting, or irregular tire wear then it should be done.
