AC light flashing
Old May 13, 2006 | 08:38 PM
tbone42's Avatar
tbone42
Default AC light flashing
AC light on my 90 is flashing in the off and auto mode also fans not coming on. I posted in teck also also coming up with code 42 could use some help hear. As you guys know i have had a bad time with shops and doing it myself now and man am i learning what makes these things tick thanks guys Tbone
Old May 14, 2006 | 09:14 AM
tbone42's Avatar
tbone42
ttt
Old May 14, 2006 | 01:25 PM
c4cruiser's Avatar
c4cruiser
The C68 Electronic Climate Control has built-in diagnostics. Follow the steps in this link: http://www.corvetteactioncenter.com/....php?qstId=142
The most common code you see with the indicator lights flashing is the 09 Low Freon detected code in Parameter 0.
Another quick wey to tell if the system is low on freon is to let the engine run and turn the A/C on. If the compressor cycles on/off every few seconds, that's an indication that the low side pressure is too low and there is not enough Freon in the system.
To AC light flashing
