Recall Issue
thanks
CHEVROLET / CORVETTE 1984-1991
Type: ANY
Recall Number: 91V143000
Summary:
UNDER CERTAIN VEHICLE OPERATIONS AND OCCUPANT USAGE CONDITIONS, THE SAFETY BELTS CAN LOCKUP OR JAM IN THE SAFETY BELT RETRACTOR.
Consequence:
IF LOCKUP OCCURS, IT IS IMPOSSIBLE TO PULL BELT OUT OFTHE RETRACTOR. THE OCCUPANT OF A SEAT WITH AN UNUSABLE SAFETY BELT ISSUBJECT TO INCREASED RISK OF INJURY OR DEATH IN THE EVENT OF A SUDDEN STOP ORACCIDENT.
Remedy:
REPLACE THE SAFETY BELTS IF THE LOCKUP OCCURS.
Notes:
SYSTEM: SAFETY BELTS.VEHICLE DESCRIPTION: PASSENGER CARS.
Additional info:
http://www.corvetteactioncenter.com/bulletin.html
http://www-odi.nhtsa.dot.gov/cars/problems/recalls/
Be well,
SJW
If you still can't get any satisfaction at this or another dealer, contact the regional service representative for Chevrolet, and explain your situation to him/her.
Be well,
SJW
Involve the regional rep if you don't get any satisfaction.
Be well,
SJW
Be well,
SJW
"Agreed. Head back to the service department (or that of a different dealer), and have a ticket written up that states that the belt has jammed on you as described in the recall bulletin. If they refuse to perform the recall, point out the potential liability issue to them.
Be well,
SJW "
"In addition to the above, I would talk with the General Mgr and if necessary the owner and let them know you will be contacting the NHTSA and advising them of the dealer's refusal to repair. The recall is a "Safety" issue mandated by the NHTSA and is effective for the life of the car, until the repair has been done. It is unfortunate but, sometimes you just gotta keep banging on them."
If, after getting it in writing, that you've had a problem and the service manager refuses to install the new equipment, it means that, (and this is IMPORTANT) the dealership has ACCEPTED THE RISK. Then you simply walk into the showroom and ask to see the general manager/owner. Point out to him what the Svc Mgr has just done on behalf of the company and then shut up. In salesman's parlance, "he who speaks next, loses." Most likely, upper management/ownership is NOT willing to accept the risk and will direct that the new retractors be installed in your car.
If that doesn't work, by all means, get on the phone and start shopping Chevy stores until you find one that will work with you.
Good luck.
