Temp question
Old May 21, 2006 | 01:07 PM
Fast Cop's Avatar
Fast Cop
Default Temp question
OK I know that vettes run hot, and my 96 vert, correct color (red/black) is not exception. My question is as follows - My digital readout shows 220 and the analog shows 250 - 260. I used a actron scan tool (CP9145) today on my Sunday morning trip to Dunkin Donuts for a coffee only, no donut and cop cracks, and I verified that the digital readout is correct as it matched the readout on the scan tool. Is their a seperate sending unit for the analog gauge or is this normal? Thanks for any help.
Old May 21, 2006 | 03:49 PM
HG's Avatar
HG
My 93 dash does the same thing, except it's in the oil temp that's off. The digital says 200 and the analog gauge says around 150. The digital display is usually accurate. I think they get the reading from the same sensor and split the reading. So usually, the analog gauge is off.
Old May 21, 2006 | 04:31 PM
Perfusion's Avatar
Perfusion
Completely normal... The analog gauges are notoriously inaccurate. For some reason, mine have always correlated well to the digital. However, I almost always have my digital display on either "coolant" or "oil" temp, so it's not an issue.
Old May 21, 2006 | 04:35 PM
KramerTamer's Avatar
KramerTamer
My '96 is exactly the same and I was told it's normal as well. I was told the analog guage is non-linear and usualy not to be trusted but the digital should be correct. Mine runs around 215 to 230 normally.
Old May 21, 2006 | 06:42 PM
POPA-VT's Avatar
POPA-VT
my 96 runs about 205. about 220 in slow traffic
Old May 21, 2006 | 08:36 PM
2008 Atomic Orange's Avatar
2008 Atomic Orange
Ditto on POPA-VT'S answer
Old May 21, 2006 | 08:50 PM
Bigredwing's Avatar
Bigredwing
I just finished a 1200+ mile round trip to Tennesse from Maryland in my '94. No mods but a Bigmouth Air Dam. Before I left I flushed my coolant system and installed new Prestone antifreeze. I replaced the main radiator hoses but did not do the thermostat. Mileage is a little over 64000. Prior to that my temp was always over 200 (averaged around 210). During this trip, including a side trip to ride the tail of the dragon I kept the digital temp readout up and only went to 202 once (that I noticed). I would have to say that for 90% of the trip the temp was between 194 and 198. Highest outside air temp I observed was about 80 degrees near Roanoke, Va. this afternoon. I was surprised and could definitely feel more power with the cooler running motor.
- Chris
Old May 21, 2006 | 08:55 PM
STL94LT1's Avatar
STL94LT1
Yes, the analog gauge's temp sensor is in the right side cylinder head, and the digital sensor is in the front of the water pump.
Old May 22, 2006 | 09:14 AM
Canam's Avatar
Canam
...my 92 is the same. I always have the digital on "cool" and monitor it that way.
Fast (other) cop.
Old May 22, 2006 | 11:29 AM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Originally Posted by Perfusion
Completely normal... However, I almost always have my digital display on either "coolant" or "oil" temp, so it's not an issue.
I do the same thing. One day I had it on VOLTS and didn't realize it. I wondered why I couldn't get the temp above 143.
Old May 22, 2006 | 02:36 PM
SunCr's Avatar
SunCr
Basic test of any analog is to disconnect it at the sender (right head) - Gage should read Lo or it coldest temp. Ground the lead and you should get Max or about 300 on the Vette. If it does that much, the cluster unit is usually good and a new sender may fix it up. You can usually buy one at NAPA. Just make sure you tell them that it's for the Analog or Dash Gage and you have an idea as to what it looks like. Most of the time they'll get it confused with the Coolant Temp Sensor (which also feeds the Digital on your Year) and bring you that part.
Old May 22, 2006 | 05:50 PM
Fast Cop's Avatar
Fast Cop
Thanks for all the great post in reference to my question. I am going to swapout the sending unit on the analog side and will report back of my findings. Just for what its worth, a whole lot to me, I think anyone who buys a vette must sign onto this forum and it is one of the best sources for vette info. Ithas saved me time and money many times. You guys and gals are great!!!
Old May 22, 2006 | 06:59 PM
Red Tornado's Avatar
Red Tornado
i agree. so far, my helms manual has COST me $$, had i not paid attention to it and opted instead to listen to the form, a certain amount of aggravation and definitely $$ would have been saved. its just worked out that way so far, due to the issues involved.
To Temp question
