Sagging head liner
Old May 22, 2006 | 01:11 AM
87vet's Avatar
87vet
6th Gear
Default Sagging head liner
Has anyone ever had a sagging head liner in your removable top - and if so how did you fix it?
Old May 22, 2006 | 01:19 AM
HOOBS's Avatar
HOOBS
I used adhesive spray in a aerosol can....worked but smells a bit.
Old May 22, 2006 | 01:25 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Peel off carefully, spray on new 3M or Permatex adhesive, tuck the material back into the frame... Repeat again next summer.
Old May 22, 2006 | 09:58 AM
C4DC's Avatar
C4DC
St. Jude Donor '06
I had about 1/3 that was hanging down. I got a can of spray adhesive and used a nozzle with a straw and a small hole in the headlner to spray some around and it is holding up fine. It has only been a couple weeks though. The windows down driving accelerates the sagging.
Old May 22, 2006 | 12:15 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Took it out and threw it away....
Old May 22, 2006 | 01:25 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
my headliner is a piece of cardboard velcrowed on with headlining material on it.
it is a piece of cake to change, pull down and pop a new one up.
you cant tell that its cardboard and it fits flush w/ the roof.
my $0.02
To Sagging head liner
