Please try ZF6 experiment (long post)...
I have a '96 CE LT4 with the ZF6. I’m sure (I think I’m sure; I hope I'm not losing my mind) that when I bought the car with 52k on the clock the transmission shifted as smooth as silk between all gears regardless of driving circumstances. But for last 7K miles or so it has felt notchy to me (64K on clock now). But only when jerking quickly from gear to gear, as if it resists being pulled into any gear quickly.
Any of you with a ZF6, please try this for me: Start your Vette and sit still with the clutch pushed in fully. Shift as quickly as possible from1st to 2nd, 2nd to 3rd, etc. Does it go as smoothly as silk? Mine does!
Now, start the car rolling; 5mph will do. Shift the same way again. Is it still just as smooth? Mine is not! It is notchy. But, if I shift slowly (normally) from gear to gear it seems to shift okay.
Is this normal functionality for a ZF6? My local dealer says so, but the tech did not seem sure & I'm not sure I trust his judgment. Plus, I could have sworn mine did not behave this way when I first got it, but I do not have a ZF6 Vette nearby to test drive myself to see. I really need to know if a new tranny will fix this, or if I'm imagining a problem that is not there.
I have replaced the following since first seeing this problem: Clutch, fork, throw-out bearing, pressure plate, clutch master cylinder (twice), clutch slave cylinder (twice), and ZF fluid (several times with GM part#).
I'm putting this in General & in Tech/Perf so that I might find a few members to try my little experiment on their cars & give feedback.
Thanks in advance guys!
David
He is the ZF guru and can answer any & all questions you may have.
You can email him or even call him...
BTW, have you checked the clutch fluid recently?
Also, the ZF fluid should be changed regularly as well...
Since I live in Phx, Bill has done regular maintenance on my trans + he installed my B&M. He rebuilds ZF's and knows everything there is to know about them.
A nice guy, Bill. Very willing to help & respond to questions as I remember.
David
The synchros don't seem to work as well at very low revs, or when the car is cool from just starting out. Especially so on the 2-3 shift. 108K miles on mine with a fresh clutch and fluid fill with GM fluid.
I also have a hurst, and mine is the same amount notchy at low or high RPMs. Only axle movement seems to affect it. (Notchy when rear wheels are rolling, not at all when stopped.)
David
Before I had my Vette I was driving a Thunderbird SuperCoupe 5 speed (awesome car!). It would be much harder to shift at high engine speeds but road speed didn't make much difference. Before I got rid of the car one of the gears was starting to grind during normal shifting from time to time. That was a Mazda transmission similat to what Ford uses in the pickup trucks.
My ZF6 (92 LT1) shifts smoothly at all road speeds and engine speeds.
You may not want to hear it but you might have to open it up to find the problem if there is one.
I am sorry I am not much help.
David
Thanks again for the feedback.
David
I know this may sound silly but is the transmission installed properly? I have heard that it is possible to install the transmission in such a way that it will not be properly aligned, and that this condition could affect performance.
Thought I would just throw that one out there.
Before changing/rebuilding your ZR, I would make sure your CHS parts are really good. Despite changing the mc/sc twice, you might still have inferior parts. I've heard about several people doing this service more than once in a short period of time. (When you replaced these parts, did you replace the hose that connects them? If not, the lining of that hose breaks down and would quickly contaminate the new mc/sc). I think the reason there were so many problems had something to do with inferior quality. And, I think recent months have started to show better production -- especially for slave cylinders.
Was there any improvement immediately after mc/sc/ZF fluid change? Have you done all at the same time?
Beyond these suggestions, I think Bill is still your best authority. I'd quiz him thoroughly before spending that much money!
http://www.digitalcorvettes.com/foru...ad.php?t=56557
But if I shift it too quickly it might feel a little tight to engage the gear.
I like the ZF6 but have found it a little dissapointing. I thought that the 6 speeds would just let me play around with it more, and found out that #6 can rarely be used ; mostly on straight boring roads, which of course I do not usually take.
That's how mine is. It even hangs up going into 3rd if I really baby it. Normal driving and banging gears at the track it works excellent. It's out of a 89 or 91.
