LTPWS diag mode
Old May 24, 2006 | 04:54 PM
corvette1989bham's Avatar
corvette1989bham
Default LTPWS diag mode
What terminals do you ground to get the LTPWS into diagnostic mode? also,how do you reset the codes?
Old May 24, 2006 | 11:49 PM
Red Dwarf's Avatar
Red Dwarf
I assume you have an 89? On that particular year I don't know which pins to use to interrogate the system. I'm sure someone will have the answer for you & this will serve to give you a bump to the top.
If you have a faulty wheel sensor there is nothing to do after you replace it. It shud reset automatically,as far as the DIC lights are concerned. You can clear any stored codes by grounding the terminals X to X number of times with in 10 secs.
Old May 25, 2006 | 09:53 AM
thebeerman's Avatar
thebeerman
On mine, when a tire is low and sets off the warning light, all it takes is a walk around to spot the culprit.
Old May 25, 2006 | 12:44 PM
SunCr's Avatar
SunCr
'89 was the first Year and the LTPWS consists of 4 wheel sensors and a Receiver which isn't linked to the ECM. There are no trouble codes and the Receiver, which is long out of production, is prone to picking up stray electrical noise and setting off false alarms. Manual Procedure for troubleshooting is to jack up the car and with the sensor pointing north (it's opposite the valve stem), hit the bottom of the tire with an air hammer. If the light goes off, the wheel sensor is bad.
If the warning lights stay illuminated after you start it, the Receiver is bad. The last time I checked, Contemporary Corvettes would sell you a used one for a 100 Bucks with no guarantee that it worked. Sensors are $150 and were still available from a Dealer.
Owner's and Shop Manual instructs you not to rotate the tires as each sensor was unique to the wheel it was mounted on. That was changed by a Service Bulletin which said it didn't matter what sensor was where as long as it had one of each color (they're color coded).
Receiver is behind the Passenger's side Crash Panel. Power and Ground is from the VATs Module.
Old Jun 20, 2006 | 03:45 AM
ol school's Avatar
ol school
Default Ltpws
First of all this doesnt nean anything is wrong with the car itself.
Look inside owners manual it give situations if the light comes on.
THE DEALERSHIP CAN ALSO DISENGAGE THIS LIGHT .
To LTPWS diag mode
