problem
Old May 26, 2006 | 06:06 AM
rockynei's Avatar
rockynei
Cruising
Default problem
I have a 2002 'Vette.. I bought it used. I hae since put a K&N filter pack on. Throttle body bypass. Iridium plugs. New plug wires. Gr anatelli MAFS. Superchip power programmer. I just recently installed a BBK 80MM throttle body and intake manifold. Everything worked fine for a while. Now when I floor it I get a traction handling problem, check engine light light and reduced engine power message. I then pull over and turn off the engine. Everything is fine except I still have the check engine light. I turn the traction switch off and floor it and once again I get the same results. Any ideas what may be the problem.
Old May 26, 2006 | 06:37 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I would start with the power programmer .Remove the info and put it back to stock .After you do that ,disconect the battery for 90 seconds and run the car.
Old May 26, 2006 | 06:41 AM
Midnite 88's Avatar
Midnite 88
The guys in C5 area might be able to give a little more insight.
Old May 26, 2006 | 07:02 AM
Aquaman92's Avatar
Aquaman92
To problem
