Fans are working and i burped the coolant lines while adding more to the top reservoir.
It happens when I idle for too long or am in stop and go traffic. Gets all the way to red line but haven't had any warnings go off yet. if i am traveling at a good speed the temps are fine...
Did you?
Open the air bleeder screws by TB (passenger side) to get the trapped air out of the motor? Look thru opening on pass side radiator shroud to be sure there is no debris in there?
I opened the screw and it was just leeking out a little. went to start the car and then it was coming out pretty good. Tightened the screw back and then put the top back on the high resovor tank.
That might be the problem since i didn't bleed the line with the lid on.... i look through the little crack to see if any debri was there and i didn't see much if any. maybe 1/4 of a leaf and some dirt or something but not enough to make it over heat that fast if not moving.
Did you check for debris between the AC condenser and the radiator? There's a little opening in the on the passenger side that you can shine a flashlight through to see. Even if there isn't anything apparent, grime gets packed in between the fins. The best thing to do is physically remove the radiator and hose it out. What I did was wrap plastic around the Opti, sprayed Gunk engine cleaner into the radiator from underneath and through the aforementioned opening, let it sit for an hour or so and then hosed it out. I did the same to the AC condenser....
the car is a 96 but has over 100k miles. I think i will try to clean out the radiator. Could i just use a blower and blow and of the debris out from the back? or do i have to take it all appart and hose it down?
Ok, air is bled and radiator looks decent. But like Tobijohn said it may still need some cleaning. I am a lot lazier than he is and cleaned mine the lazy way. I simply took an old wrapping paper tube, sorta formed a 90* opening on one end and taped the other end to my shop vac. It was amazing what I sucked out of an other wise clean looking radiator.
But let me ask you something else first. Using the digital temp gauge what hi temp are you getting. Don't forget the main fan doesn't come on until 227-228 degrees and the aux fan at about 236-237, which on the analog gauge is pretty close to the red line area. GM feels that is optimum eng op temp for best emissions, I don't agree, but then what do I know. Anytime you turn the ac on the fan comes on and cools it down. Personally I rarely sit in traffic, but still plan to get the fan temps reprogrammed to come on sooner (ecm programing, not a chip).
Hope this helps.
The lowest it goes is the first notch past the 185 mark. Then when i let it sit for 5min it goes all the way to the begining of the white/black checkard area. and in stop/go traffic it usally can be found in between the two.
I will try the shop vac thing and see if that helps clean some crap out. Along with bleeding it again to make sure i did it right.
I don't use the digital read out but will definitly check it out to make sure it isn't my guage messing up. Since i never get a warning or think it is that hot.
My 95 never gets that hot. I might see it just pass the 230-240 mark idling. You will know when it gets too hot. The engine will be sluggish and start acting like it wants to die from a 91 vette experiance. I would clean around the radiator and if nothing there and you get the air out, and see no coolant leaks, then I would assume faulty thermostat.
Sounds like a good plan. When bleeding it wrap some rags around the bleeder so the a/f doesn't drip down on the opti. I do it engine off, then engine running, then lastly engine running and t/stat open (over 195 in my case) When you get everything else doen and start running it watch the digital gauge closely to see when the fan kicks in. Let us all know after that.
ps--the 'upper reservoir' is actually a coolant surge tank.
...I don't use the digital read out but will definitly check it out to make sure it isn't my guage messing up. Since i never get a warning or think it is that hot.
When I initially got my 96, I flipped out the first time I saw it get up there. The consensus here was and is that these temps are normal for these cars, some even say necessary. That notwithstanding, I just couldn't stand watching it get that high so I got a Hypertech PPIII along with a 160 thermostat and programmed the fans to kick in sooner. Here's something else I discovered: the analog and digital gauges are attached to different temp sensors. I think the analog is in the cylinder head and the digital is somewhere in the system on the cool side of the radiator. In addition, the analog is not that accurate. There's even a sticker from the factory somewhere saying that very thing.
As for cleaning out the radiator, I should have removed it to clean it out thoroughly but I didn't. Just sprayed Gunk in there and hosed it out. I'll bet repeating the process would be better but as I said, better still would be to remove it and clean. It's not a complicated procedure but I'm a lazy guy who's jinxed with tools (something always seems to strip or break) so I did it the way I previously descibed.
Could also be a stuck thermostat if not changed lately.
When I brought my 96 LT4 home in March it was running to hot for my taste so 160 sat and a tune to kick the fan on sooner helped it alot. One note the new fule with 10% eth in it now makes mine run cooler a trips a code on the back cat O2 sen, eth does not burn as hot as the old gas.
This whole discussion has given me some ideas. This whole temp thing with mine is freakin me out too
With a 160 sat and a tune to set the fans on at 180 my vette even while waiting at the bank drive thru 80* out side temp she never whent over 215 with the AC on plus 16500 miles on the clock.
Remove the radiator cap and start the engine, then run it up to operating temperature. Note your temperature readings. Insert a quality mercury thermometer in the coolant and check the temperature.
You may be surprized. When my digital gauge indicated 210° F, the thermometer read 170°.
I pulled my radiator and the area beneath was fairly clean. I have seen photos of others though, and you won't believe the amount of derbis that can be sucked up. Our cars are road vacuums! Warning: Be extremely careful of the radiator fins. They are more fragile than a virgin's heart. Do not touch them with anything, even a feather.
When I fixed my blown head gasket, temps went down 10°. I think it had been leaking slightly for a long time - years perhaps.
Wetter water did me no good. It was a waste of money. Others report very good results.
Regards,
Rich
OKAY.....there is a little more debris in there then i thought. still i don't think it would have been enough to make it run this how. I tried the shop hose with a wrapping paper tube bent to 90 degrees and it was too hard and started to bend the ridges some so i stopped that. then i had a soft brush that could get in there and it just didn't get anything out. How hard is it to take the shroud off? i think i need more room or a better plan then what i am doing now.
Use the Advanced Search function, check both current and archive boxes, type in "radiator removal" and select the entire C4 section. There's all the info you'll need....
Don't bend the paper tube. Slice a circle out of it at the end on one side, then tape or cap of the end. That way it is sucking at a 90* angle. Then slide it thru the opning and work it around over the surface of the radiator. You want to be gentle with it so as to very gently rub against the cooling fins, let the vacuum do the work, don;t try to use the tube as a scrub brush. Just saw the pictures, it looks pretty clean and the air filter looks like new.
