Replacing front spoiler?
Old May 28, 2006 | 06:18 PM
nelson84's Avatar
nelson84
Default Replacing front spoiler?
Did anybody do this and were your nuts and bolts rusted together? Did you have to drill them out and if so did you drill them from underneath or did you drill them from the top? Or is there a secret way to get these rusted nuts off?
Old May 28, 2006 | 06:33 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Since I'll be doing this within the next couple years...
Old May 28, 2006 | 06:51 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
i had to drill the rear ones off when i was replacing the rear. the front sould be drillable from the inside(remove hood to help). though i would try wd-40 first
Old May 28, 2006 | 06:53 PM
RICEKILA's Avatar
RICEKILA
From: Beautiful Down Town "SWINDLEHURST" Long Island NY
I put a Z-51-ish one on ( with brake cooling scoops), About 10 or 12 10mm bolts ( only about 1/2" long) into sheet metal c-clipy things. The day before soak or spray with a lot of "P B Blaster" and get 1" or 1 & 1/4 long bolts it makes the reassembly easier. Simple job
Old May 28, 2006 | 08:57 PM
CREWZIN's Avatar
CREWZIN
Replaced mine with a single piece from Mid America called the "Prowler". Did it a lot of years ago and none of the nuts/bolts were rusted so they came out pretty easily. I did have some help as it's a lot easier with someone working on top and the other under the car.
Old May 28, 2006 | 10:47 PM
Ericsvette's Avatar
Ericsvette
Just replaced mine (all three pieces) last week no rust here.
Old May 29, 2006 | 12:01 AM
nelson84's Avatar
nelson84
I striped the bolts on one side and the middle and I cut 3 bolts off the middle one with a hack saw and drilled one out, tomorrow I will tackle the two outer ones with those drill bits for stripped screws and hex bolts, more work than I planned.
To Replacing front spoiler?
