Low tire pressure warning system
Old May 29, 2006 | 10:47 AM
Weely's Avatar
Weely
Default Low tire pressure warning system
I have a 1992 LT1 coupe. The "Service LTPWS" light comes on at about 45 mph and stays on. I gather that this means my low tire pressure warning system is not working correctly. My shop told me it would cost about $400 to check out and possibly replace the main unit and/or the sensors in one or more of the tires. I don't mind not having this LTPWS feature at all and just checking the tire air pressure once in a while. But the waring light on the dashboard bugs me. Is there a way to make this light stop coming on without spending a lot of money? Can the LTPWS system be disabled without too much trouble? Thanks for any help.
Old May 29, 2006 | 11:06 AM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
$400 to check out!
it is simply pulling codes to see what "failed"
the way to diasable LTPWS is to pull the bulb
Old May 29, 2006 | 11:11 AM
tomtom72's Avatar
tomtom72
St. Jude 15 Year Donor
Active Streak: 90 Days
St. Jude Donor '08 thru '26
I've a 90 and I think the system was changed some time during the c4 run...I just don't recall when. That said my Helm manual has a diagnostic flow chart for pulling the codes in the LTPWS and it gives the meaning of each code. If you have a manual and a scan tool you can read the DTC. There is also a diagram of the ALDL terminal and it shows which pins to touch to read the DTC's for the LTPW system.
Tom
Old May 29, 2006 | 08:09 PM
gmtech921's Avatar
gmtech921
the parts are expensive and each sensor in those early gen's is different. (set for each wheel) chances are that the sensor is gone bad in one or more wheel. the sensors arent like the newer style valve stem they mount inside the wheel and are just expensive... sorry to break it to you. I am not sure that there is a way to actually "make the light go out" with out fixing it....
Old May 29, 2006 | 09:36 PM
Red Tornado's Avatar
Red Tornado
a good used sensor can be had from a salvage yard for about $75. for your year, a new one is about $160 from the dealer.
test each sensor, one at a time by doing this:
deflate one tire to 20 psi, then start the car and drive.....at least 2 mins. and/or 25mph. if the ltpws lamp goes on, then that sensor is good. inflate that tire back to its normal rating (about 35 psi). repeat this for each of the other tires, until you find the one that doesn't illuminate the ltpws lamp --- this will be wheel with the bad sensor. once you've obtained another sensor for that wheel, go to NTB (they only charge $8 for installation of the band sensor for you), and you'll be good to go.
each sensor is color coded with its own part number.
i can't see that the ltpws receiver module would be bad, assuming that both "low tire pressure" and "service ltpws" lamps go on upon startup, then go off after a couple seconds (like the other bulbs in the DIC).
so, you have either $75 + $8, or $160 + $8 for the fix, assuming just one sensor is bad. cost of diagnosis, instead of $400 is $0.
$400 for a simple diagnosis thru the steps i outlined above is what is known as highway robbery. tell your shop to go blow.
Old May 29, 2006 | 09:44 PM
LNO's Avatar
LNO
I've got the same problem on my 96. Dealer diagnosed two bad sensors. How do you know if a sensor purchased from a salvage yard is good?
Larry
Old May 29, 2006 | 09:46 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
and a Tip-O-The-Hat to a man who just saved you $400.00
Old May 29, 2006 | 09:49 PM
Red Tornado
Larry
you don't unfortunately. i have no problem purchasing parts this way, but thats me. i bought a used sensor from a good forum member here for $60, he couldn't verify it was good either....i said no problem, understood, i'll take it.....and its turned out golden. its up to the individual of course.
Old May 29, 2006 | 11:16 PM
gmtech921's Avatar
gmtech921
the codes will break down to what sensor at what corner is bad. another question I ask since I have seen this a few times is, did you have any tires dismounted? i.e. flat, new tires etc. that can help I have seen tire monitor issues soon after tire work. or maybe due to age a sensor just gave up.......
Old May 29, 2006 | 11:55 PM
Red Tornado
you're correct, in my case codes don't set in the receiver (for '87 - '90 they don't).....so my FSM doesn't explain.....i should have made this distinction.....please advise the original post as to what the procedure is for pulling the LTPWS codes to determine the bad sensor(s) for his '92 --- which aldl terminals are pinned?
the procedure i outlined would still work as a backup diagnostic, the "manual method". also --- he'll need to get the code(s) cleared from his receiver module --- he won't be able to clear them on his own --- will he need to go to the dealer for that?
Old May 30, 2006 | 10:01 AM
Weely's Avatar
Weely
Thank you all very much for your advice. I appreciate it.
Old May 30, 2006 | 03:20 PM
gmtech921's Avatar
gmtech921
pull codes ( ground a-b) if it is a wheelsensor code it will be a 24 (r.r),34 (l.r) 44 (l.f.) 54 (r.f) then replace the appropriate sensor. the code should clear out once all sensors are signaling. hope this helps.
Old Jun 20, 2006 | 03:13 AM
ol school's Avatar
ol school
Default Ltpws
Mine came on after playing with tire pressure.once I put pressure
on the factory specs.(on the driver door) the light stayed off.
My 96 cold 30psi. Also if you read your manual it tells you of other reason why this light comes on .
Is it LTPWS or is it SERVICE LTPWS these lights come under strange circumstances such as riding next to another car with LTPWS that has low pressure tires.Damaged sensor (if you had new tires put on recently) ck your pressure on your tires .Makes a BIG differance .
This doesnt mean anything is wrong with your car , you can even have the dealership eliminate the light.
SERVICE LTPWS which is a little differant comes on if you turn the ignition on three times in row within a half hour without moving your car. or if the sensors are missing.
Some weird S--t . Anyway Hope this helps..
Old Jun 20, 2006 | 03:15 AM
ol school's Avatar
ol school
Default Ltpwsw
Yes this can be disengaged without no problems See dealer
To Low tire pressure warning system
