Cooling Fan Problems
Old May 29, 2006 | 03:34 PM
W89's Avatar
W89
Default Cooling Fan Problems
I Have A 84 Vette A Bought Been Fixing It Up I Cant Get The Fan To Work When The Motor Is Running? I Have But In A New Relay, Fan Switch Sensor,coolant Temp Sensor Still Can Get The Fan To Work When The Motor Is Going. I Can Put A Jumper Wire Between A,e In The Relay Fan Comes On, I Can Put A Wire To The Fan Switch Connector And Ground It The Fan Comes On. Tested The Fusebox And Everything Is Getting Voltage But When I Start The Motor Up And It Heats Up The Fan Nver Comes On.the Only Thing I Can Think Is There Something Wrong In The Ecm ? Got Any Ideas ? Thanks
Old May 29, 2006 | 03:44 PM
RRT vette's Avatar
RRT vette
What temp do you let it get to before deciding the fans not coming on? I changed my ECM and now my fan comes on at 230* rather than 170*.
Old May 29, 2006 | 03:54 PM
W89's Avatar
W89
I Think It Was Pushing About Close To 230 I Was Thinking It Should Come On Way Before That But Maybe I Need To Let It Go To 230 Or So.?
Old May 29, 2006 | 03:58 PM
RRT vette's Avatar
RRT vette
I wouldn't let it get to 240*. That might be pushing it. Mine only gets to 230* when idling. With a 180* thermostat, while driving it stays around 180*.
Old May 29, 2006 | 10:32 PM
tbone42's Avatar
tbone42
Wow does this sound like what i just went through.I was thinking it was my ecm also and replaced it but it was not the problem.I have a 90 so i know it's different but worth a shot.Check the ten amp fuse for the gauges that was the problem with mine also my gauges did work with the fuse blown hope it helps Tbone
To Cooling Fan Problems
