Another Oxygen Sensor Question
Old May 29, 2006 | 09:39 PM
LNO's Avatar
LNO
Default Another Oxygen Sensor Question
Searched the posts on oxygen sensors but didn't find anything on How to Replace one.
Got a 96 LT1 and SES light was on. Took it to Autozone and they told me it was a L/H rear oxygen sensor. Engine runs fine in idle and at highway speeds.
My question is, where in the rear seneor and how do I replace it (Tools?)?
Thanks for the help
Larry
Old May 30, 2006 | 01:01 PM
LT1SPUD's Avatar
LT1SPUD
it's behind the cat converter....do you have the helms manuals? if not, i can scan the replacement procedure and e-mail it to you...
Old May 30, 2006 | 10:33 PM
LNO's Avatar
LNO
I have the Chevrolet shop manuals for this car and they show a drawing of where the sensors are, but what I am unclear about is how to access the sensors. I looked under the car while it was on ramps and I can hardly see the sensor let alone put a tool on it.
Any suggestions?
Thanks for the previous response.
Larry
Old May 31, 2006 | 07:17 AM
rocky1's Avatar
rocky1
Are you sure that it's the sensor and not the cat? You can get a code for the catalyst monitorying oxygen sensor when the cat stops working.
Regards,
Mike
Old May 31, 2006 | 02:49 PM
LNO's Avatar
LNO
Regards,
Mike
I would think that if the cat had stopped working, the engine would run rough. The engine runs fine. The only reason I know something is wrong is the SES light is on all the time the engine is running. A couple of weeks ago, the SES light was intermittent, sometimes on and sometimes off. It stays on now.
Larry
Old May 31, 2006 | 07:47 PM
stormin310's Avatar
stormin310
What is your code I think i pulled a code 141 bank1 post-cat drivers side after cat.....Was about 2 years ago bought 1 at autozone for about $50 replaced it no more problem ses cleared.....Looks like a spark plug screwed into tail-pipe the harness was a bitch to get disconnected though.........
Old Jun 1, 2006 | 07:24 AM
RRT vette's Avatar
RRT vette
Jack up the car and take a look, not hard to find after the cat. Make sure the wiring hasn't touched the exhaust to cause the fault reading.
To Another Oxygen Sensor Question
