I have noticed that while on the freeway my
new to me '93/conv, FX3, will just want to
change lanes. Anything over 65 and the car
will suddenly drift to the left.
Now I have a "service suspension" light that
has been coded as a bad shock/actuator on the left
front. Had the actuator rebuilt by Aaron and
now have 2 new shocks for the front but not
yet installed.
I know this sounds like the no brainer reason
for the car doing this. However I think it's just
the adjustable part of the shock that is not working
and is otherwise doing fine. So after shock replacement
and erasing error code what would you folks
recommend? Four wheel alignment probably is
next step?
Car is otherwise fine at lower speeds.
Thanks,
Craig
I'm no mechanic so take my thoughts for what they're worth. On my C4 it has a tendency to "go with the crown" if it is "severe". It will for sure get caught in seams on concrete roads & if there are big ruts in asphalt with the 275's up front.
How is it on a flat road? Is the shock leaking badly, like really down on fluid? Other than those things...alignment & are the calipers okay, not sticking? Otherwise I'm with you on the new shocks & the alignment.
The adj. suspension shouldn't have anything to do with it. Once an actuator goes, the whole adj. susp. sys. shuts down and cannot be switched. However I had an 87 that needed a 4-wheel alignment. Only way I knew was when I would hit joints in concrete pavement, the rear would kick to one side. Once the alignment was done, that stopped.
I also agree that because of the wide tires on these cars, they can sometimes track the crown in the road.
Tramlining is the tendency of a car to follow ruts in the road.
It can be mitigated with changes in alignment settings.
I use VBandP "Advance Street settings" It virtually eliminated my tramlinning issues
From: SCMR Rat Pack'r Charter Member..Great Bend KS
One bad shock...on any suspension...will not cause a sudden darting to one side.
I'd look at alignment (front and rear), ball joints, toe rods, tie rods, wheel bearings, and tires...in that order. Take the car to a good alignment shop and have them check these things.
Good luck and tell us what you find to be the cause.
I just had my car aligned using the VB&P advanced street settings and it definitely made a big difference...feels more secure at any speed and around corners. I think my old alignment was way out of wack.
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
Wow, thanks guys!
I think the pavement has a lot to do with it and it does
also seem to happen when I stop accellerating. Gotta
keep both hands firmly on the wheel.
Will go to the alignment shop. Anyone know the best one
on the east side of Detroit?
Craig
I recently had the same issue with my 96 vert. I started with a 4 wheel allignment. Still drifted to the left. Pulled the tires off the front and swapped them for test only, yes I realize they are directional, and low and behold when I did it now pulled to the right. Put them back on the right side, went to the local tire Firestone dealer who pronounced that I had a bad left front. The tires were Firestone Firehawk SZ50's, which are now discontinued and have been replaced by the Firestone Firehawk Wide Oval. So after some dealing and a quote from tire rack the Firestone dealer matched the tirerack price and gave me a 50% credit on the bad tire.
Two new tires on the front and my baby now tracks stright and true, and the little drift left or right from the crown of the road is not a car problem its the road which is made like that for water run off.
I'm having this issue. I just drive from CA to VA. My 95 goes to the right. I tried everything and still pulls. A CF member told me that it may have a bent frame
I hope not a bent frame. If he is right then you should have bad inside wear on your left steer tire and bad wear on outside of the right steer tire. I assume a good alignment shop has confirmed the bent frame theory? Your vette looks too nice to have such a problem.
