I am trying decide if I should repair the Bose unit or pull it and replace it with something better. The CD player has issues which seems to be a common problem. If I decide to replace, what will fit the space?
Thanks for any help.
Replace..........go to audio section for more info. Search the topic.
I would replace it. Stereo technology has come a long way since our cars were new. You can put a standard size head unit in the car with an installation kit to make it fit. There are some manufacturers who have the larger size that fits the factory opening completely. I believe Pioneer is one and they refer to the size as a din and a half in our cars.
I have a sony head unit and amp with a six disc changer in the rear compartment, the one on the passengers side. There's more to just changing the head unit though because the bose speakers have amps built into them. There are some guys on here who really know this stuff and I'm sure they'll chime in shortly.
if you decide to repair it, I had Dr. Don's do it and give it the capability to play CD-R's. I then installed an FM transmitter that is powered by the cigarette lighter so that I can use my IPOD on 88.3...I also have a 10 CD kenwood changer in the rear storage compartment thatalso has a FM transmitter.
you can do a search online and find dr. don's bose stereo repair ...Im happy with the job they did and the speed of the repair and return.
I like the new stereo systems, but I just didnt feel like changing my car's interior look...its just my personal preference.
If it's a cost issue, you'll make out well by looking on ebay for a used Bose head unit. I just did that for my dad's car and saved a few hundred bucks. I replaced mine with a nice Alpine several years ago and it wasn't difficult. You will need a wiring harness kit, a dash kit that the new deck fits into, and possibly a couple of line level adapters if you're maintaining the Bose speakers.
Dump it AND the speakers. Go to the Audio section and read the C4 sticky. Some very cool info there.
I see you are new to the forum. Replacing the Bose in my car was the reason I found the Forum. Not only did I find the info and parts I needed here, but info on just about anything else that had to do with my car. This is a great place!
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
If you are not a real audiophile, I'd suggest that you look in the yellow pages and find a local auto radio repair place. Call them and ask about having the CD player component replaced and the head unit checked.
The 88 Vettes did not offer a CD player so I installed a used 94 Camaro head unit that looked just like my original Bose tape head unit but had a CD player. It worked ok, but would skip easily and didn't like my home burned CD-Rs. I took it to a local auto radio restoration place, and for $230 out the door they replaced the CD component with a new one. It looks factory and plays great. I was going to send the speakers to Bose for repair/upgrading, but with the new CD unit they sound like new. It required no re-wiring, looks stock, and sounds great with my home burned audio CD-Rs.
if you decide to repair it, I had Dr. Don's do it and give it the capability to play CD-R's...
I'm not sure I understand. Do you mean the stock Bose CD player will NOT play compilation music CDs that you burn yourself? Even if they're created using the same format as the record companies use on original CDs? Or do you mean it's not capable of playing MP3s burned to a CD-R? TIA...
I'm not sure I understand. Do you mean the stock Bose CD player will NOT play compilation music CDs that you burn yourself? Even if they're created using the same format as the record companies use on original CDs? Or do you mean the capability of playing MP3s burned to a CD-R? TIA...
Old CD player, doesn't know how to decode any format but wave files.
My 86 has a world class casstte deck. Woof.
Old CD player, doesn't know how to decode any format but wave files...
I don't think the individual tracks on a commercial music CD are in the wave format. I believe it's something else. Guess I'll hit the Internet to confirm that, though...
You are correct the native format is AIFF.
If you burn your own CDs, I burn all my own from iTunes it will convert your AAC or MP3 files to AIFF (assuming iTunes) and you'll be fine.
R&R the Bose. I personally like it, it kicks butt in my opinion all those aftermarkets system look just like that aftermarket. They just don't fit or flow with the interior.
Check out Dr. Don's, I had mine redone by him he did an excellent job and I upgraded the CD unit with a later generation model. It's not that much more.
R&R the Bose. I personally like it, it kicks butt in my opinion all those aftermarkets system look just like that aftermarket. They just don't fit or flow with the interior....
Thanks, Lani. I've got CD Creator and I've used it to create my own "Best of" CDs which worked fine in a RF modulator CD changer connected to my stock non-Bose AM/FM/cassette. So I assume that these CDs will work in the Bose CD player, correct? And if at the time I could have replaced it with an aftermarket player that even remotely looked liked it belonged in the dash, I would have. But I looked at a ton and none did...
Don't want to hijack, but you can get iTunes on your PC too. It'll bring over all your existing stock of music as well. It's so easy, you create a play list, drag the songs you want from albums or the library, select the playlist and choose burn playlist to CD. That's it, iTunes takes care of the rest. Those AIFF are huge in comparison to say MP3 or AAC, say a 6MB MP3 will be about 60MB AIFF.
As long as it native format you should have no problems whatever s/w you use.
Another nice thing which I believe most folks know is when you buy a DRM latent downloaded music burning it to a CD removes the DRM. (Tip it's the playlist that is limited to 7 burns, so changing the playlist by one song will allow another 7 burns.) Shhh don't tell tho...
