turning signals
Old Jun 5, 2006 | 07:21 PM
ZDRpewter01's Avatar
ZDRpewter01
Default turning signals
I don't understand what the problem is. When I go to use the turn signals they both barely flash.
Old Jun 5, 2006 | 07:31 PM
bsmutz's Avatar
bsmutz
Probably a ground problem.
Old Jun 5, 2006 | 07:36 PM
c4cruiser's Avatar
c4cruiser
Same thing happen when you use the 4-way hazard flashers?? If not, then it may be a bad turn signal flasher. Are the brake lights bright when you step on the brake?
Old Jun 5, 2006 | 08:47 PM
ZDRpewter01
Hazards work fine and so do the brakes. I put in new bulbs today so thats not the problem. When i turn the lights on the work good also.
Old Jun 5, 2006 | 09:41 PM
ZDRpewter01
no help?
Old Jun 6, 2006 | 12:26 AM
jfb's Avatar
jfb
The turn signal flasher works on lamp current. More current, faster flash rate, low current, slower flash rate. If you have a slow flash rate and even with a new flasher, then you do not have all of the turn signal lamps on, or you have a poor connection in the lamp socket or a poor ground connection causing lower lamp current. Watch the lamps (front and rear) with the turn signal on, are they full brilliance? Don't forget the side marker lamps in the front.
Old Jun 7, 2006 | 12:06 PM
ZDRpewter01
I checked all the lights and they are in the sockets good. when i hit the flasher it makes a weird click noise for each blink, my radio dims on each blink, and they blinkrs that are signaled to flash barely light up.
Old Jun 7, 2006 | 12:25 PM
red_johnny's Avatar
red_johnny
Sounds like a bad ground to me also. But that is kinda odd since I would not believe that all the lights have a central ground. It maybe the signal flasher.
Old Jun 7, 2006 | 04:09 PM
JIMBO7's Avatar
JIMBO7
Default Bad Ground
had the same problem. Poor ground!! Took a little while to find. It was not making good contact in a bulb socket. Easy fix!! You can do it!!
Old Jun 7, 2006 | 04:14 PM
ZDRpewter01
thanks ill go try right now
Old Jun 7, 2006 | 04:17 PM
SJW's Avatar
SJW
Add blinker fluid. It's probably low.
Be well,
SJW
Old Jun 7, 2006 | 04:23 PM
poplife's Avatar
poplife
Be well,
SJW
Blinker fluid?
Old Jun 7, 2006 | 05:21 PM
red_johnny's Avatar
red_johnny
Yeah, you dont know about blinker fluid? Have you ever taken exhaust samples? How about have you ever had to get a box of grid squares for a map?
Old Jun 7, 2006 | 07:44 PM
SJW's Avatar
SJW
Originally Posted by poplife
Blinker fluid?
Available here:
http://kalecoauto.com/index.php?main...&products_id=6
Be well,
SJW
Old Jun 7, 2006 | 08:00 PM
red_johnny's Avatar
red_johnny
SJW, thanks for that. Very helpful link. Now I know where to find elbow grease
Old Jun 7, 2006 | 08:39 PM
papidos's Avatar
papidos
Be well,
SJW
That blinker fluid must really work good, they're all sold out !! Lucky for me they still had the Muffler Bearings in stock. I got 2 of them, one for each muffler. Can't wait to install them.
Old Jun 7, 2006 | 11:35 PM
ZDRpewter01
I found that the problem was that they gave me a light bulb with only 1 connection point on the bottom and corvettes need bulbs with 2. Thnks for all the info I'll make sure to put it to later usage.
To turning signals
Old Jun 8, 2006 | 09:25 AM
JIMBO7's Avatar
JIMBO7
good find, lizard! always pays to check the bulb base when installing
hot dam!
Old Jun 8, 2006 | 09:42 AM
SJW's Avatar
SJW
Good find. Vettes, being fiberglass, don't rely on chassis ground for those sockets, hence the extra contact and wire.
You're still probably overdue to change your blinker fluid, though. Every 150,000 blinks is the recommended interval...
Be well,
SJW
Old Jun 8, 2006 | 01:30 PM
ZDRpewter01
Just for information purposes here is the instructions forthose who do not know how to change your blinker fluid........
http://www.geocities.com/changeyourblinkerfluid/
