actuators
Old Jun 6, 2006 | 02:02 PM
thebeerman's Avatar
thebeerman
Default actuators
For those of you who haven't had the pleasure of working with Aaron and Lynn at Captain Z I would suggest you give them a call or email if you are having problems with, or considering upgrading your actuators. They were willing to check out three actuators I sent them, two with cracked housings that didn't work. Two they were able to get working that were frozen, even tho they had cracked housings, they made them functional and charged me $25 to make them usable, suggesting I just epoxy the holes/cracks and use them till they quit then throw them away. The best one they rebuilt with their new gear set (an improvement over the oem plastic gears) and I have a better than new actuator for $125. A good service, and a good group to work with. If you are wondering what to do with your actuators contact aaron@captainzinc.com, I highly recommend them.
Old Jun 6, 2006 | 03:03 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Are you talking about headlight motors here? I fixed both of mine for less than $2 using bushings from Home Depot....
Old Jun 6, 2006 | 03:46 PM
mrmoore's Avatar
mrmoore
No. FX3 shock actuators. Aaron did mine, too.
Old Jun 7, 2006 | 05:49 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
Wow that was nowhere close to clear in his post.
Old Jun 7, 2006 | 02:24 PM
thebeerman's Avatar
thebeerman
Sorry, I didn't even realize that the headlight motors were also referred to as actuators. I was referring to the FX3 shock actuators. It is an affordable alternative to buying new, $300+ units.
Old Jun 7, 2006 | 03:10 PM
onedef92's Avatar
onedef92
I agree. Thanks for the tech tip.
To actuators
