[SMOG]: Passed!!!!
Old Jun 7, 2006 | 01:40 PM
Perfusion's Avatar
Perfusion
Default [SMOG]: Passed!!!!
Woo-HOO!!!!
I put a can of Seafoam through the car (1/3 in the crank case, 1/3 in the gas tank, and 1/3 into the intake via the brake booster line) yesterday afternoon... MAN did it smoke! Smelled somethin' awful, too... Anyway, I went back to the station that did my original (failed) test on Monday, and ran another pre-test. The numbers looked great (NOx was down by about 100ppm), so I had 'em run a real one.
Ugh...it failed *again* - NOx was 509, and the upper allowable limit is 424.
I was and and then
This morning, I decided to try a different SMOG place. This time, a "Test-Only" station (vs. a regular repair shop that also does SMOG testing). I figure, they have nothing to gain if I fail..
Sure enough, my car passed with FLYING colors - all parameters were well within normal limits, and the troublesome NOx component dropped by nearly 150ppm.
Anyway, I'm very happy, and just wanted to share it with everyone!!!
Time to
Aaron
Old Jun 7, 2006 | 01:42 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Glad to hear it!!!! I wonder if it was the first station's "other agenda" or if the Seafoam really helped. Well, this time we won't know altho many others have said it's of some benefit. Good luck from now on!!
Old Jun 7, 2006 | 01:45 PM
red_johnny's Avatar
red_johnny
Wow, Good for you. I am thinking of trying out seafoam as well but not for passing emissions.
Old Jun 7, 2006 | 01:49 PM
bogus's Avatar
bogus
glad you passed!!!
it makes me wonder about the calibration of the other shops test equipment. either that, or the cats were hotter, doing a better job.
now, change that oil... I didn't know you can put seafoam into the crankcase... that sounds scary.
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
SEAFOAM. it's a good thing. Add it to your things to do to the vette when you do an oil change. When I did it to my 96 it was pretty clean, but my 89 chevy truck killed all the misquitos in a two square mile area. LOL.
Old Jun 7, 2006 | 01:59 PM
Perfusion's Avatar
Perfusion
I think it was a little bit of both... The Seafoam DEFINITELY got the carbon out of it. I think the car was just too hot on the 2nd run yesterday (the real test), but on the pre-test it was too high. My numbers at the Test-Only station today were still significantly lower than the pre-test yesterday, making me think that the other shop's calibration must be off - intentionally.
I'm definitely getting another can of Seafoam and running it through the wife's Jetta. Although she doesn't have to SMOG this year (car is less than 5 years old), it can't hurt. The car will DEFinitely run better, that's for sure.
Old Jun 7, 2006 | 02:25 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
i love sea foam
Old Jun 7, 2006 | 02:28 PM
TM-Z06's Avatar
TM-Z06
Glad to hear it. I take it the "Test-Only" shop didn't do a extreme visual?
Old Jun 7, 2006 | 02:34 PM
Perfusion's Avatar
Perfusion
Hardly any visual at all! The guy busted out the broom stick with a mirror on the end of it and a flashlight. I think he was just checking to see if it had cats, which it *does*, and that was that. His only remark was,
"Dual exhuast?"
I said, "Yep...why?"
(he had my printout from yesterday) "The other shop had you down as "single"...<sheaks head in disbelief>..."
To [SMOG]: Passed!!!!
