Head light help
Old Jun 7, 2006 | 03:38 PM
cemittar's Avatar
cemittar
Default Head light help
Can anyone tell me were the headlight motor relay and solenoid is on a 1987 coupe manual????
Old Jun 7, 2006 | 04:26 PM
poplife's Avatar
poplife
Found in the FSM.
Old Jun 7, 2006 | 08:01 PM
cemittar's Avatar
cemittar
Originally Posted by poplife
Found in the FSM.
FSM?
Old Jun 7, 2006 | 09:01 PM
aminnich's Avatar
aminnich
FSM?
Factory
Service
Manual
That is the 'bible' for fixing your own vette, also called the Helms manual. I can't help as mine is 95 and wiring is different. Try a search in the tech help section here. Good luck with it.
Old Jun 8, 2006 | 12:39 AM
Demonic85's Avatar
Demonic85
I didnt know there was a solenoid for the headlights, but the relay is located on the driver side next to the fender. If you follow the wiring harness from the headlights you'll find all of them on that side.
Old Jun 8, 2006 | 01:01 AM
newbecorvetteguy's Avatar
newbecorvetteguy
Don't know about a solenoid, but there are I believe 3 relays mounted together on the left inner fender towards the front. There might be a cover over them. Mine are out in the open but I see a small hole where there might have been a screw holding on a cover. Car was 17 years old when I bought it so I never know what's supposed to be what for sure.
What problem are you having?
Old Jun 8, 2006 | 07:29 PM
cemittar's Avatar
cemittar
I swaped from EFI to carb and the guy that bought my ECM wanted the harness to go with it (all of it) so I pulled EVERYTING out. Now I gotta wire everything myself. I got everything to work except getting the headlights to open and close with out having to do a bunch of CRAZY wiring.
To Head light help
