idle setting/timing
Old Jun 18, 2006 | 10:30 AM
genoa's Avatar
genoa
8th Gear
Default idle setting/timing
This week I set the idle and tps on my 1985 Coupe. All went fine and it works well. I used instructions I found through this forum and they were self explanetory. This process does not touch timing. Should the timing be set during this process? I am not sure where I read that it should but I am curious.
Old Jun 18, 2006 | 11:28 AM
goldeneye_vet's Avatar
goldeneye_vet
It can't hurt and for me I usually do the timing first, followed by the IAC and then the TPS. Nothing but 5 minutes more.
Old Jun 18, 2006 | 12:05 PM
jimmers's Avatar
jimmers
I always check the timing when I set the idle speed. It doesnt take long and wont hurt!
Old Jun 18, 2006 | 01:00 PM
Muffin's Avatar
Muffin
I think the proper sequence is timing,TPS then IAC. At least that is what my manual says.
To idle setting/timing
