alternator question
Old Jun 20, 2006 | 10:47 PM
ignatz521's Avatar
ignatz521
Default alternator question
I have a 92 LT1 and I've already replaced the alternator twice since i got the car and the power starts off at 14.7 and then ranges in between 13.8 and 14.1.Is this normal?
Old Jun 20, 2006 | 10:49 PM
c4sforever's Avatar
c4sforever
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
yes
Old Jun 20, 2006 | 10:50 PM
vader86's Avatar
vader86
normal
Old Jun 21, 2006 | 12:34 AM
JD'S WHITE 93's Avatar
JD'S WHITE 93
Old Jun 21, 2006 | 02:24 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
You have an LT1 ,check the wires that run down the intake ,you might have a short.
I had to replace my plug on mine when it started giving me problems.
I got a wake up call on that one $35.00 big ones for a stupid plug.
Old Jun 21, 2006 | 09:58 AM
SJW's Avatar
SJW
Lead acid batteries require less voltage to charge as the ambient temperature rises.
Charging voltages for lead-acid batteries are typically in the 2.30 to 2.35 volts per cell range at high ambient temps, and 2.40 to 2.45 volts per cell at low ambient temps.
Charging at 2.40 - 2.45 volts/cell at high ambient temps can result in a severe overcharge and damage to the battery.
For this reason, the voltage regulator (which lives within the alternator on your C4) is temperature-compensating. What you're seeing is normal, and by design.
Be well,
SJW
Old Jun 21, 2006 | 10:03 AM
cosmicvette's Avatar
cosmicvette
Be well,
SJW
Great info. Thanks
Old Jun 21, 2006 | 11:32 AM
ignatz521's Avatar
ignatz521
thanks for the info on the alternater question,this is my first vette and i was a little worried since my car only has 70,450 miles and i have had the car since Dec.2005 is there anything else i should know?
Old Jun 21, 2006 | 11:39 AM
ignatz521's Avatar
ignatz521
Old Jun 21, 2006 | 02:01 PM
SJW's Avatar
SJW
Owned it since December? By now, you should know how to have fun.
But, seriously... Anything else you should know about what?
Be well,
SJW
Old Jun 21, 2006 | 03:42 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
If you have not done this since you purchased the car, change all of the fluids: Oil, tranny & rear diff and use synthetics. ALSO be sure that you all the special GM additive into the rear diff for the posi clutches.
Read the tech tips at the very top of the tech/Perf section. You'll learn a lot form that.
Old Jun 21, 2006 | 05:09 PM
ignatz521's Avatar
ignatz521
I have nothing but fun every time I drive the car however things are starting to go wrong,such as the ride control, But as far as fun theres nothing like taking the roof off and cruising,and winning shows
To alternator question
