paint help
Old Jun 21, 2006 | 11:14 AM
96lastc4's Avatar
96lastc4
Default paint help
Hi
My car is Polo Green and I had it waxed a couple of weeks ago. Now every smallest mark in the paint looks like a hard water mark. How do I fix this or just keep waxing it? It did look very nice when I got it back but after a couple of washes these started to show up.
Old Jun 21, 2006 | 12:15 PM
DFWLCJ's Avatar
DFWLCJ
St. Jude Donor '07-'08-'09
You may want to check in to the Car Care Forum section...more info than a normal person can absorb
A suggestion might be to do a complete Zaino job (or polish of preference)...start with a "dawn" wash to remove polish/wax...then clay bar...then build up polish of choice from there...you'll be amazed at the results. The clay bar removes the water spots etc. and the finish is incredibly smooth ... I used Zaino Z5 to remove swirl marks and then alternate Z6 and Z2
Good luck
Old Jun 21, 2006 | 12:30 PM
Jet-Jock's Avatar
Jet-Jock
I would add, after claying it use Zaino ZPC and a PC-DA buffer to polish the entire finish then put Zaino Z5 Pro on it.
A PC-DA will run you about $115 plus a pad kit from Sonüs (bettercarcare.com).
Hence the results:
Old Jun 21, 2006 | 03:39 PM
96lastc4's Avatar
96lastc4
sorry how and what is a clay bar?
Old Jun 21, 2006 | 05:31 PM
Jet-Jock's Avatar
Jet-Jock
http://www.zainostore.com/Merchant2/...ory_Code=Zaino
Old Jun 21, 2006 | 08:04 PM
1stC3Vette's Avatar
1stC3Vette
Clay bar works well. You can also try a "cleaner" wax followed by a polish.
Good luck,
Dino
To paint help
