Torq-Thrust offset
Old Jun 21, 2006 | 11:15 AM
Lichen's Avatar
Lichen
Default Torq-Thrust offset
I have a "93 and was looking at the American Racing wheels websites. They have Torq-Thrust II offsets listed for the early C-4's, but not the later ones. They do however, have a listing for 93+ Camaro/Firebird. The 17x9.5 offset is 46, and the 17x11 offset is 45. Will these work on my '93?
Old Jun 21, 2006 | 04:49 PM
Lichen's Avatar
Lichen
Since nobody answered, I'm going to take that as a yes. Seems like they would only stick out less than 1 cm more than stock offset.
Old Jun 21, 2006 | 05:32 PM
c4cruiser's Avatar
c4cruiser
The OEM 9 1/2" wheel offset is 56mm so the T-T wheels are off by 10mm for the 9 1/2" wide wheel. That's a 10mm difference so there should not be any problem for this width wheel.
The OEM 11" ZR-1 wheel has a 36mm offset but the 1996 Grand Sport 11" wheel has a 65mm offset. There was a 3" difference in the width of the ZR-1 body at the rear end compared to standard C4's so that was the reason for the difference in offset for the OEM wheels. The chances are that the T-T 11" wheel with the 45mm offset may stick out beyond the fenderwell lip.
Old Jun 21, 2006 | 08:58 PM
Mint Charcoal 88's Avatar
Mint Charcoal 88
they will stick out approx 3/4". I have 315's on 11" with the 45 offset in the rear. The front also is sticking out the same so it looks OK. contact Luke at tire rack over on the tire/wheel forum for his expert opinion. he will be able to answer all your questions..
Old Jun 22, 2006 | 02:58 AM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
If your willing to pay list, the TTII's can be custom ordered in the exact (56) offset you want.
Old Jun 22, 2006 | 03:04 PM
Lichen's Avatar
Lichen
I just went down to Discount tire and ordered a set of them. 17x9.5 and 17x11. I also had to order new rear GS-D3's to fit the rear rims. I'll post pics when I get them next week.
Old Jun 23, 2006 | 11:11 AM
finnor's Avatar
finnor
On my 96 I went with 17x9.5 all around with 46mm offset, BFG G-Force Sports 275/40/17. The rears are pretty close to flush, the fronts are flush at the rear edge, and stick out a tiny tiny bit towards the front.
--Tor
To Torq-Thrust offset
